NA 416 High Compression Build - 2011 Camaro
Old 10-02-2023 | 03:50 PM
  #101
logan2ss's Avatar
Originally Posted by 02EBC5Z06
Sorry, somehow just saw this.. I am hoping the car makes at least 600 whp.
What does your car weigh with you in it now?
I will message you on FB
The following users liked this post:
02EBC5Z06 (10-02-2023)
Old 10-04-2023 | 08:50 PM
  #102
jayyyw's Avatar
131mph
logan2ss (10-04-2023)
Old 10-04-2023 | 08:51 PM
  #103
02EBC5Z06's Avatar
Originally Posted by jayyyw
131mph
I'll give him 135
The following 2 users liked this post by 02EBC5Z06:
jayyyw (10-04-2023), logan2ss (10-04-2023)
Old 10-04-2023 | 09:41 PM
  #104
logan2ss's Avatar
High 130s to low 140s would be great. 60-130 makes it seem promising. Geared for 145 in the 1/4 at the top of 4th so that should work nicely for what I’m hoping to trap
Old 01-16-2024 | 05:32 PM
  #105
logan2ss's Avatar
Okay I know I have not been on here in a while but I am interested to hear if anyone has data on this. I have talked about doing it for years but never took the risk. The 3.01 (or 2.97) 1-4 gear set vs the 2.66 close ratio set, and why? I have the stock 3.01 wide set and always had a terrible bog hitting that 4th gear in the mid 5000s, the car really seems to come to life about 6500 in 4th. If I swapped to the 2.66 close ratio set this would bring me up 600rpm ish of where I land in 4th gear, getting me past that hump in the bottom of the gear. But is it going to be a major change on starting line ratio where it will be a major loss out of the hole? The car is not near 3900-4000 like factory, just looking for insight. I am expecting to hear that it depends whether I want to dig race or roll race more, but I should be at the top of 4th gear in the 1/4 if that helps. Some people chiming in with experience on both seems like a long shot but would be awesome info. TIA
02EBC5Z06 (01-16-2024)
Old 01-17-2024 | 10:28 PM
  #106
jayyyw's Avatar
I switched to the 2.66 trans. I went from a 26" to a 28" tire too. My 100-130 was .2 faster with the 2.66/28". That's also the difference between shifting into 4th at 110mph and shifting into 3rd at 98mph. Acceleration seems pretty close. All things equal, with tire size, I think the 2.66 will be slower for you. My 60-100 is faster on the 2.66 only because I can use, somewhat, 2nd gear, instead of leaving in 3rd.
Old 01-17-2024 | 10:59 PM
  #107
logan2ss's Avatar
this basically perfectly sums up what my thoughts were. I was talking with a buddy this morning and verbatim told him I would expect a .2 gain factoring in shift time, and that gain being from a 2nd gear start vs 3rd gear. I’d probably gain about the same, I start in 3rd for 50 rolls and higher.
Old 01-17-2024 | 11:56 PM
  #108
jayyyw's Avatar
Going to a 28" tire should mimic the 2.66/26" pretty closely, at least in 2nd/3rd. You can see how that affects your 60-130. Only thing that will suffer will be that 3-4 shift. But much cheaper than swapping the trans.
Old 01-18-2024 | 07:56 AM
  #109
logan2ss's Avatar
that’s the whole reason I’ve wanted to ditch it was to rid of the 3-4 bogging and be able to try 2nd gear leave. My guess has always been .2 gained on the 60-130. So the bulk of the gain to you was the 2nd gear leave and not so much the closer ratio 3-4? Just making sure I understand correctly
Old 01-18-2024 | 08:28 AM
  #110
02EBC5Z06's Avatar
Here is a good site to see the gearing vs speed charted out
https://legacypic.uk/transmission/graph.php
Old 01-18-2024 | 08:33 AM
  #111
logan2ss's Avatar
oh yea I have been glued to the screen on legacy, blocklayer, and gearcal. One of those things where you drive yourself crazy until you just try it yourself. Unfortunately that is a bit more spending for an experiment than I would normally care for. Plus if I was to decide to switch to the 2.66 set, I would do it to my current trans. I would do the 2.66 1-4 and try to keep the 3.01 5-6. Would make for a perfect split trans imo - at least on rolls.
Old 01-18-2024 | 08:34 AM
  #112
02EBC5Z06's Avatar
I guess for me, just trying to shorten the shift point between third and fourth would be the biggest thing.
Old 01-18-2024 | 08:38 AM
  #113
logan2ss's Avatar
Yeah I always hated the drop off from 3-4, really noticed it badly next to cars I was really close with but they had modern 10 speed transmission. Glued together in my 2nd, 3rd, and top of 4th gear, but always fall back when it falls to the bottom of 4th. Now another internal battle being do I want to focus on roll race gearing or potentially look into drag racing the car more. The drag racing is coming back to me, but may have me prefer the 3.01 gear set.
Old 01-18-2024 | 08:41 AM
  #114
02EBC5Z06's Avatar
This is what I get with my combination on the 26. To me, it seems like it won't be a large falloff on the 3-4 like it used to be with the 3.42. I am also planning on giving it about 1k more shift rpm though.
Then again, maybe I am not reading this right and it will still be a noticeable lag in acceleration once in 4th. My biggest issue on the old sbe ls6 combo on motor, was that 3rd gear was just lazy unless I was already moving. The new motor is going to make a lot more torque, so that coupled with the 3.90s vs the 3.42s should make a noticeable change.
Old 01-18-2024 | 08:57 AM
  #115
logan2ss's Avatar
Here is my comparison that I run with the 3.01 gear set (left), vs the 2.66 gear set (right). Both are using 4.10 gears and running a 25.7 tire. Redline is 8200 but figuring on a realistic 8000 shift. Even keeping the shorter tire on the 2.66 test shows a usable 2nd gear on a 60 roll, even better if I went up to a 28''. The 3-4 is where I feel I would really make the difference. The car hits 3-4 like a slug and does not feel alive until about 6500 rpm. My current setup shows to land to about 5600 in 4th and the gear set change would land me around 6200. I feel like that would be an amazing change on my personal setup. If I start doing more 1/4 mile stuff then my opinion starts to change on what is best for me.
Old 01-18-2024 | 11:30 AM
  #116
spanks13's Avatar
What about the 2.66 ratios and a shorter rear gear?
Old 01-18-2024 | 11:48 AM
  #117
LaBLKv6Z's Avatar
Originally Posted by logan2ss
Making a first thread for my build in process. I have a 2011 Camaro 2SS with a TR6060. Recently got my motor back from the machine shop and the goal is to reach some 9s in the 1/4.
LS3 Based 416
-Smeding 4'' Forged Crank
-Molnar Power Adder 6.125 Rods
-Custom JE Pistons w/ Gas Ports
-ARP Main and Rod Hardware
-GPI Custom Grind Cam
-Brodix BR7 Heads w/ PAC 1209x - 50cc Chamber
-15:1 SCR
-Holley Hi Ram w/ 1” Spacer
-Bosch 210 Injectors
-103mm TB
-2” Headers
-Meziere EWP
-Improved Racing Crank Scraper
-25% UDP
-Vararam CAI
Car is pretty light for a 5th gen. Going to see how it acts with E85 but going fuel cell as well and going to mess with some other fuels.
Apologies if I missed it but are you still running the original 2 piece driveshaft? Recently, I've installed a couple of once piece DSs onto this platform (1 Carbon and 1 Chromoly). Along with the DSS upgraded axles.
  #118
logan2ss's Avatar
My current 4.10 is the deepest rear gear you can get for the 8.6 IRS rear end. I could always entertain a solid axle swap and my choice of gear for a small 10-15k, lol. Ultimately a 2.66 gear set with a 4.56-4.88 on a 28'' tire would be money imo
Old 01-18-2024 | 11:54 AM
  #119
logan2ss's Avatar
I do have stock axles in it and always have. I have gone through 2 driveshafts (one custom steel, one DSS) and never had much luck, so I reverted back to the stock 2 piece again. Should be okay on highway stuff. I have my doubts of it doing well if I get back to the track.
Old 01-18-2024 | 07:43 PM
  #120
Double06's Avatar
How long is that driveshaft?
Quick Reply: NA 416 High Compression Build - 2011 Camaro
