Ly6 cam options
229/245 .621"/.604" - 112 Lobe Center Angle with a 108 Intake Centerline
We have a couple of LS3/Rec port flavored cams. The first one we'd look at is our Pro LS stage 3 "extra clearance" SUM-8710R1. Specs on it are .625/.605, 230/242, 113+3 with 10* of overlap. The 8710R1 will allow the heads to be milled slightly and maintain PTV clearance. Things vary so we recommend checking PTV before final assembly. It has a strong steady lope and accelerates hard in the mid-range and top-end. Stock gearing is ok but we recommend a 3,000+ stall converter. Pair it with some .660" lift duals and it'll be happy out to 7,000+.
A step up from there would be our Pro LS stage 4 "extra clearance" SUM-8711R1. Specs on it are .625/.605, 234/248, 114+3.5 with 14* of overlap. You'll have a strong lope with the 8711R1. It's designed for maximum acceleration with the factory style intake. The 8711R1 is the largest Pro LS cam we offer that will fit an LS3 with un-milled heads. As always we recommend checking PTV before final assembly. We recommend deeper gears and a 3,500+ stall converter when going with the 8711R1. It'll be happy out to 7,000+ with .660" lift duals.
We know our customers like combos so we offer a variety of combos for most of our Pro LS cams.
- For 8710R1 combos check here
- For 8711R1 combos check here
Let us know if we can be of any further assistance. We'll be happy to help!
- yea but will they also clear in Ly6 thats what I have.
or
Summit Racing Stage 2 Cam 226/238 .600/.600 113 + 3
3:73 or 4:10 gears with a 3600-4000 Stall
I have an FTI 3200 Stall with 3:73 gears which to me is too tight. That's why I say a 3600-4000 stall
You'll need some pushrods as well. We typically see a 7.425" pushrod used with the 8710R1. Things can vary so we always recommend measuring for pushrod length before purchasing pushrods. If you don't already have a pushrod length checker we offer the Trickflow TFS-9501. For pushrods, we recommend a minimum of a 5/16" Chromoly pushrod with a .080" wall. You can typically find a set of 16 for around $100. From there you can get into a thicker wall or larger diameter pushrod. For excellent stability and strength check out our 11/32" HDR pushrods with a .120" wall. These have 25% less stress and 28% less deflection than a typical 5/16" x .080" wall Chromoly pushrod.
