Engine build thread
Old Nov 6, 2022 | 10:01 AM
SteveJewels's Avatar
Veteran: Navy
Default Engine build thread
I met with Preston at BES to go over my build. He liked the heads and recommended some clean up of the combustion chamber and porting the exhaust.
The plan looks like this;
Engine to replace LS3 in 2010 Corvette
I don’t expect it to make more than 12 to 14 PSI, probably less
I will run it on a boost limiter at ~800 WHP most of the time with a “push to bass” to override ~ 1,000 WHP
E85, triple Fore fuel pumps, 1,300 cc injectors, sufficient for 1,200+ WHP
427 CI, Vortech V-3 billet Ti CSC
· Block
Aluminum, Gen IV, Darton sleeved by Race Engine Development, RED, block cast number is 12571048
Large sleeves for 4.125” bore, 5.800” length
Align hone
Bore to 4.125”, Torque plate
Katech Billet Steel Main Cap Set, Part #KAT-A4122 or equivalent
Bore for dowels
· Crankshaft, Molnar, 4” stroke
· Connecting rods, Molnar PWR ADR
· Heads, Dart Pro 1, 15 deg 280cc, 68cc, 11:1 >/= CR </= 11.5:1, Clean up combustion chamber and mild to moderate porting of exhaust
· Pistons, JE Pistons Ultra series
· Valves, Ferrea 6000
· Lifters, Johnson ST 2116 or 2126 lifters
· Pushrods, Strongest, stiffest you can find, 5/16” ball
· Valve Springs, PSI, Rate to match cam
· Retainers, Tool steel
· Head gaskets, BES choice
· Head studs, ARP 2000
· Main studs, ARP
· Cam, profile to be determined after heads and valves, Cam Motion
· Cam Bearings, BES select
· Main Bearings, BES select
· Oil pump, Melling 10355, high pressure
· Timing set, TBD
Old Nov 6, 2022 | 10:03 AM
Veteran: Navy
12571048 block as received at RED
Dart Pro 1 280 cc LS3 heads
Old Nov 6, 2022 | 02:12 PM
Awesome Steve. Please keep us updated.
Old Nov 9, 2022 | 11:07 PM
jayyyw's Avatar
Auto or manual?
Old Nov 10, 2022 | 05:47 AM
Veteran: Navy
Started life as an A6 and now has a RPM Level VII 4l65e.
Old Nov 11, 2022 | 11:36 AM
grinder11's Avatar
Start a tire fund....SOON!!!
Old Nov 11, 2022 | 01:58 PM
FormulaBoat's Avatar
At what point is 6 bolt head LSX stuff justified?
Old Nov 12, 2022 | 10:14 AM
Veteran: Navy
I have a pair of 345 Michelin Pilot Super Sports for road trips like when I go to Corvettes at Carlisle. Most of the time I am running Toyo 345 R888R's.
Tires are a consumable, like gas.
 Michael S. Palmer
