Comp cams custom spec'd camshaft
Old Dec 3, 2022 | 07:19 AM
Yoji h 123's Avatar
Default Comp cams custom spec'd camshaft
What information would I need to give comp cams to spec out a custom camshaft for a 5.3 single turbo setup?
Old Dec 3, 2022 | 07:49 PM
rpturbo's Avatar
I don't know what the minimum is, but the more, the better. Including static compression, chamber CC, car weight, gear ratio, ECT.
Old Dec 3, 2022 | 11:16 PM
KW Baraka's Avatar
Get with Cam Motion. Unlike Comp, they actually have guys who are knowledgeable in spec'ing cams.
Cam Motion High Performance LS Camshaft & LT1 Cams
KW
Old Dec 4, 2022 | 08:58 AM
68Formula's Avatar
I'll summarize generically:
Minimum:
  • Engine displacement
  • Fuel system type (carburetor or EFI)
  • Boost and type (Naturally Aspirated, Nitrous, Single Turbo, Twin Turbo, PDS Blower, Centrifugal Blower)
  • Vehicle weight
  • Rearend gearing
  • Transmission gear ratios
  • Torque convertor stall (if applicable)
  • Intake
    • Carburetor or throttle body size
    • Intake manifold
    • Cylinder Head (brand, part number, runner size)
  • Exhaust
    • Headers type and size (shorties, long tubes, primary diameter)
    • Full length with mufflers or open headers
    • Catalyst equipped
  • Tire
    • Diameter for effective gearing
    • Width
    • Type (drag/autocross offroad only, street-legal drag, mud/rock, road course)
  • Static compression ratio
  • Intended fuel: E10 87, E10 91, E85 pump (which can vary as low as 51% ethanol), C16, Methanol injection
  • Max rpm shift point
  • Planned use:
    • How much street cruising vs. offroad use
    • Type of offroad use (autocross, road race, 1/8 mile, 1/4 mile, mud, rockcrawling)
Helpful:
  • Bore/Stroke/Rod Length (if different from stock)
  • Quench distance
  • Maximum boost
  • Turbo size
  • Intercooler if applicable (and type)
  • Exhaust size (dual, single, pipe size)
  • Elevation where used if extreme (Pikes Peak for example)
Old Dec 4, 2022 | 03:17 PM
LilJayV10's Avatar
Originally Posted by yoji h 123
what information would i need to give comp cams to spec out a custom camshaft for a 5.3 single turbo setup?
everything.
Old Dec 5, 2022 | 11:19 AM
grinder11's Avatar
KW
X2 on Cammotion......
Old Dec 6, 2022 | 05:41 AM
Yoji h 123's Avatar
Minimum:
  • Boost and type (Naturally Aspirated, Nitrous, Turbo, PDS Blower, Centrifugal Blower)
  • Vehicle weight
  • Rearend gearing
  • Exhaust
    • Catalyst equipped
  • Tire size (diameter for effective gearing and width for traction)
  • Planned use:
    • Type of offroad use (autocross, road race, 1/8 mile, 1/4 mile)
Helpful:
  • Maximum boost
  • Turbo size
_Minimum:_
* Boost and type 30+psi single turbo and 35 shot or 75 shot of nitrous to get to 30+psi
* Vehicle weight 3175Ibs
* Rearend gearing 3.73
* Transmission gear ratios 2.48 1.48 1.00
* Torque converter stall (if applicable) 4500 to 4800
* Exhaust bullhorn
* Headers type and size (shorties, long tubes, primary diameter) 1 7/8 by 3 kook's turbo LS swap fox body mustang header's
* Catalyst equipped no
* Tire size (diameter for effective gearing and width for traction) 28 inch
* Static compression ratio 9.2:1
* Intended fuel: renegade pro 120+ nitrous or VP racing c16
* Max rpm shift point 7500rpm
* Planned use: drag racing
* How much street cruising vs. offroad use no street cruising offroad use only
* Type of offroad use (autocross, road race, 1/8 mile, 1/4 mile) 1/4th mile
_Helpful:_
* Maximum boost 30+PSI with help of nitrous 35 or 75 shot
* Turbo size precision turbo 80/85
* Intercooler if applicable (and type) no using nitrous 35 or 75 shot and to spool turbo
* Exhaust size (dual, single, pipe size) what ever works with turbo that is not restrictive
* Elevation where used if extreme (Pikes Peak for example) summit motorsports park and south georgia motorsports park
Old Dec 6, 2022 | 06:19 AM
Mavn's Avatar
"I MAID THEESE"
Now send that to cam motion lol
youll need CI, Head type, intake manifold, piston info, cc chamber, head gasket thickness. etc. aswell
_Minimum:_
* Exhaust bullhorn
_Helpful:_
Old Dec 6, 2022 | 11:22 AM
Yoji h 123's Avatar
Minimum:
  • Vehicle weight
  • Rearend gearing
  • Intake
    • Intake manifold
  • Exhaust
    • Catalyst equipped
  • Tire
    • Width
  • Planned use:
Helpful:
  • Quench distance
  • Maximum boost
  • Turbo size
_Minimum:_* Boost and type 30+psi single turbo and 35 shot or 75 shot of nitrous to get to 30+psi * Vehicle weight 3175Ibs* Rearend gearing 3.73* Transmission gear ratios 2.48 1.48 1.00* Torque converter stall (if applicable) 4500 to 4800* Exhaust bullhorn * Headers type and size (shorties, long tubes, primary diameter) 1 7/8 by 3 kook's turbo LS swap fox body mustang header's* Catalyst equipped no * Tire size (diameter for effective gearing and width for traction) 28 inch* Static compression ratio 9.2:1* Intended fuel: renegade pro 120+ nitrous or VP racing c16* Max rpm shift point 7500rpm* Planned use: drag racing * How much street cruising vs. offroad use no street cruising offroad use only * Type of offroad use (autocross, road race, 1/8 mile, 1/4 mile) 1/4th mile _Helpful:_* Maximum boost 30+PSI with help of nitrous 35 or 75 shot * Turbo size precision turbo 80/85* Intercooler if applicable (and type) no using nitrous 35 or 75 shot and to spool turbo * Exhaust size (dual, single, pipe size) what ever works with turbo that is not restrictive * Elevation where used if extreme (Pikes Peak for example) summit motorsports park and south georgia motorsports park and barona drag strip 325CI Cathedral port Summit racing fabricated intake manifold 102mm bore 4500rpm to 8500rpm Custom mahle pistons 7.19 dish 64CC chamber 0.051 head gasket thickness
