125psi oil pressure
Please let us know what you find.
Thanks!
This is a quote from my machine shop: The Oil clearances on that engine and every other LS engine is pretty tight, that’s why I said use 10W-30, first thing that happens is oil cannot transfer through the crank and bearings so it won’t allow enough oil to escape the bearing and be thrown up into the piston skirt area, I hope this has not caused an issue already because it will. The higher pressure that you’re having now is because the oil is so heavy it’s being backed up in the system."
Change the oil and monitor things closely moving forward. Then go slap the idiots at the shop who installed the engine.
For the parts receiving pressurized oil (bearings, lifter bores, etc.) there is likely not much of a chance for issues since the oil pressure indicated there was oil aplenty at those locations. As your engine builder said the issue would be those parts relying on splash oiling such as the piston skirts, cylinder wall, rings, rollers on the lifters. The rockers are probably fine as long as they were properly prepared on assembly.
An oil analysis will tell you if wear was excessive, but this was a fresh engine so the metal particles in the oil will be much higher than normal anyway. The trick will be to determine if they were excessively high for an engine break in. The only other way to know for sure unless there are other obvious signs, would be to tear the engine down and physically inspect things and remeasure the clearances.
