Here we go, 450ci LSx, Mast 285cc LS7 heads...
That looks like a killer build. Only 1 thing I question just a little bit is going HR rather than SR. I know HR has come a long long way. Guess I'm stuck in the 70s. Please-keep us posted. BTW, what happened to the RHS block built previously?....
Thanks. Im running a rmvb 4l80 built by Extreme Automatics. Gunna use a 9.5" FTI hard hit converter without lock up...prolly a 4k ish stall. Waitn on a dyno sheet before I call them up. I dont really have any goals per say. 600+ at the tires feels about right. Car is on a small drag radial(255/60/15). Lotsa adjustable suspension to play with. Sure be nice to get into 9s effortlessly and drive it home with ac, stereo, back seat, etc. Car is to nice to cut up for a tub n bigger tire. With the full frame in these A-bodies, its a lot if work and will most certainly lose the back seat.
I questioned staying HR too. Eric didnt seem worried about it at all. I started thinkn SR n be done, but he told me not to worry. RHS block is chinese garbage and had poroscity issues. It was doa. Its in my other build thread, including the method I used to test the block with hot water. I got a refund on the block, sold what I could, and kept what I needed for this build.
The RHS blocks are junk. They ve had tons of issues over the years...Builders like Mast, Chad Golen, etc stopped using them. Mine was doa. I had overwhelming proof it was DOA, and they still fought me on the refund. It was during the covaids years and they didnt have any in stock or an eta to replace with new(which I would have just sold). They dont even own a system to test the block the way I had to. It only leaked when warm, under operating temperatures. Try and recreate that scenario. I did!
The following 5 users liked this post by rkupon1:
02EBC5Z06 (03-13-2023), KnightmareLS1 (01-22-2024), LCBE (02-07-2023), n2xlr8n66 (01-25-2023), Saber-1 (10-25-2023)
The following users liked this post:
rkupon1 (01-25-2023)
rkupon1 (01-26-2023)
in for results
The following 3 users liked this post by rkupon1:
What is it called when you run water through the block at operating temps during honing. Would it beneficial to do do it during boring too?
anyone??
anyone??
rkupon1 (02-06-2023)
The following 6 users liked this post by rkupon1:
ALL ULL C (02-16-2023), brutalzo6 (02-16-2023), cdubbzz (02-17-2023), Double06 (02-16-2023), Guy with a Chevy (02-16-2023), and 1 others liked this post.
rkupon1 (02-16-2023)
The following 8 users liked this post by rkupon1:
02EBC5Z06 (03-19-2023), ALL ULL C (02-17-2023), brutalzo6 (03-12-2023), Che70velle (02-17-2023), Double06 (02-18-2023), and 3 others liked this post.
#37
Looks great with that manifold up top.
rkupon1 (03-11-2023)
