First start up engine won't turn
Old Jan 25, 2023 | 03:14 PM
ToxicBiz's Avatar
Default First start up engine won't turn
So I finally got power to the car. Now I'm trying to prime the oil but the starter is not turning the flywheel. I took out all of the spark plugs and tried to turn the engine by hand and it won't turn. It turned just fine before connecting the m6 trans and putting the engine in the car. Are these two things related? What should I check for? Battery is brand new all the parts are also brand new.
Old Jan 25, 2023 | 05:39 PM
Full Power's Avatar
Transmission in neutral ?
Correct flywheel ?
Old Jan 29, 2023 | 10:11 PM
01CamaroSSTx's Avatar
If the transmission is in neutral you should be able to turn it over by hand unless the starter is hung up on the flywheel. Did you remember that you have to push in the clutch to turn it over with the ignition key? It wouldn't be the first time this has happened.
Old Jan 30, 2023 | 08:12 AM
ddnspider's Avatar
Yank the starter and turn by hand and go from there.
Old Jan 30, 2023 | 09:34 AM
LS299S10's Avatar
You said you tried turning it by hand. Said it turned by hand before installing the transmission.
The problem seems to be the transmission.
Old Feb 1, 2023 | 12:13 AM
ToxicBiz's Avatar
So it 10000% turned by hand before putting it in the car. I just removed all of the transmission clutch and flywheel and it still won't do one full turn. I'm at a loss I don't understand. I guess all I can do now is drain the oil and start breaking it down. I suppose I'll start with the push rods and rockers.
Old Feb 1, 2023 | 12:15 AM
ToxicBiz's Avatar
Correct flywheel ?
Yes and yes
Old Feb 1, 2023 | 12:16 AM
ToxicBiz's Avatar
That's what I thought and hoped but after pulling it all it still won't do a full turn. Only about 3/4 of a turn.
Old Feb 1, 2023 | 06:37 AM
ddnspider's Avatar
Back off the rockers and see if it turns then. Also pull the starter.
Old Feb 1, 2023 | 07:58 AM
jasons69chevelle's Avatar
How hard was it to put the transmission in. Lots of force? Did you use the bolts to pull the transmission to the engine? I’m thinking the crank maybe jammed forward into the thrust bearing.
Old Feb 1, 2023 | 08:09 AM
Was it turning over by hand with the rocker arms installed? Could be possible you missed a lifter cup when installing the PR's and now it's binding up.
Old Feb 2, 2023 | 12:46 AM
ToxicBiz's Avatar
Yes it was all installed when it would turn over. I'm gonna try to loosen the rocker tomorrow
Old Feb 2, 2023 | 12:47 AM
ToxicBiz's Avatar
Old Feb 2, 2023 | 12:49 AM
ToxicBiz's Avatar
No problem getting it in the engine. Did not use the bolts to pull it in. Is it possible the bolts pulled the crank to the back?
Old Feb 2, 2023 | 05:45 AM
Gene Cheeseman's Avatar
The transmission install is the problem. If it turned over with the rockers on before why are you going to mess with them?
Old Feb 2, 2023 | 06:15 AM
ToxicBiz's Avatar
The transmission is out now and it still won't turn 100% over.
Old Feb 2, 2023 | 08:39 AM
ddnspider's Avatar
Knew that was coming....hence the reason I asked you to pull the starter and springs. Putting the trans in just so happens to correspond when you tried turning it over. Your problems are in the engine.
Old Feb 2, 2023 | 09:38 AM
grinder11's Avatar
Thus is an unusual LS problem!!! If it spins 360° after rockers are removed, either a bad trunnion, or valve to piston...
Old Feb 2, 2023 | 09:41 AM
LS299S10's Avatar
1000000% something dropped into an intake port.
Did you pull the intake to install it?
Old Feb 2, 2023 | 10:04 AM
Engine turned 360° with the rocker arms installed and before transmission was installed but now after removing the trans it dosen't? I find it strange to all of a sudden have an internal issue which leads to other questions like was the timing cover, valve covers, windage tray and oil pan installed at the time the engine was turning over by hand? I'm pretty sure that bolting a flywheel to the crank isn't going to keep it from turning over either and if so the problem would have been with the flywheel and visible. If for some reason the thrust is the issue this should have been verified before the connecting rods went on. Just as you should be checking for side clearance after rod/piston install.
