Darton Sleeved 5.3 Blocks
5.3L iron truck blocks tend to be used because they are readily available and inexpensive. And the truck engines don't have any bay-to-bay breathing holes in the main webbing so there is added strength for high power applications. Downside is you don't have bay-to-bay breathing which helps with oil control & return.
Also, I think the builders prefer iron blocks from a manufacturing process perspective because it is much easier to modify for sleeves. The block is machined to accept the sleeve and then the sleeve pressed in. Aluminum blocks have sleeves from the factory that have to be removed, and then the block is prepared to accept the new sleeve. The process with aluminum block is more difficult and time consuming, but it gives similar benefits of stronger liners and capability for larger bore and longer stroke.
For everyday builds they're going to use the most economical block as a starting point. That's the 5.3L for iron block, and the LS3 for aluminum block. If you have your own LS2, LS7, or aluminum 5.3L then they'll use it if you ship it. You'll have a tough time finding somebody to sleeve your LS1 because the block is thinner in critical areas and typically don't have such a good outcome.
I know that Dart blocks have .375 longer cylinder barrels than OEM so that is probably in-line with the sleeves.
A quick search says a Gen 4 aluminum 5.3 weighs 121lbs. (Claim was more than Gen 3 aluminum block), 6.0 iron weighs 211lbs., and the Dart iron Pro next block comes in at 227lbs. Not sure what a sleeved 5.3 block weighs but I’d think a few lbs. more than what it started as.
I mean if you wanted to really prep a sleeved block for forced induction and RPM, your talking a 1/2” head studs, perhaps block/head hoops, and pinned billet mains but you’d be awfully close or over the cost of a final machined Dart block at that point. If you are class racing and aftermarket blocks are not allowed then that is your option. Dart block you get better oiling, billet mains, and additional head bolts.
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
