Cam housing wear?
Cam housing wear?
Normal spun bearings or just housing wear is typically in the opposite direction but mine is going in the direction of the block essentially to the back, its a little wear but i have never seen something like this before, just picked up the block sunday and its in great condition but since i have never seen this type of wear and couldnt find any information from anybody else on it and wonder if its fixable and i assume it is, also want to know what its from. getting my block honed and cleaned up aswell as my heads and is this something they could fix.
https://drive.google.com/file/d/1N3i...usp=share_link
https://drive.google.com/file/d/1JNy...usp=share_link
Not totally sure what you're asking about?
Looks to me like a normal block that has had the cam bearings removed normally, and now needs a new set normally installed. Or am I missing something?
The following users liked this post:
strutaeng (05-11-2023)
"Cam housing"?? Do you mean the cam bearing bores? They don't wear...
Those marks are nothing unusual. Remember that the aluminum is very soft, and easily gets marked up when bearings are pressed in and out. You probably don’t even want to look at the top of the cam bore, as it gets scratched up pretty good by this:
Although I see no problems here, it should be noted that oversized cam bearings ARE available should the bores become truly damaged.
That line is either from some one hammering them out with a drift or from the parting line on the bearings it self. As long as they measure on size there shouldn't be an issue. The radial marks are from the machining process. Each housing bore has a specific bore size and bearings to match.
Durabond CH-10 Fits LS engines with, 1st Design; 99-03 Positions 1 and 5 Housing Bore 2.3260 Inch /2.3280 Inch, Cam Bearings
Durabond CH-23 for the 2nd design were discontinued and replaced by the CH-25. which are the same .O.D. but wider.
Here is the pictures of the bore he is questioning.
- Fits LS engines with 2nd Design Positions 1 and 5 Housing Bore of 2.3460" /2.3480".
- Fits LS engines with .775" Wide Bearings in All Positions.
G Atsma (05-15-2023)
When it comes to aluminum blocks, I've been told by a couple of other engine builders that they prefer using blocks that have had the fewest cam bearing changes. They claimed that after 5 or more cam bearing changes, the aluminum bores wear a slight amount, increasing likelihood of the cam bearings walking. FWIW......
The following 2 users liked this post by Che70velle:
MySons68C20 (05-21-2023), strutaeng (05-20-2023)
