Yet another cam choice thread but with a twist (updated)
*Source: Motor Trend article What Is the Biggest Camshaft for a Stock LS3 6.2L V-8? (motortrend.com)*
Numbers on an engine dyno, fwiw.
"The 8710 cam picks up 26 degrees of intake and 31 degrees of exhaust duration at 0.050, and 0.074/0.080-inch lift. It clears the stock pistons, making it the largest drop-in cam Summit offers for a daily driver. We noticed immediately that the engine revved easily to 7,000 rpm. Peak torque moved from 4,800 rpm to 5,400 rpm and gained 22 lb-ft for a total of 492 lb-ft with more than 400 lb-ft from 2,800. Horsepower increased from 484 at 6,100 to 549 at 6,600. With a little more cylinder head and intake flow, it would have continued to make power past 7,000. Not bad for a weekend's work."
Hydraulic Roller CamshaftAggressive PerformanceDuration at .050": 220/232110 Lobe Center Angle with a 106 Intake CenterlineLift with 1.7 Rocker Arm Ratio: .595"/.586"Recommended Displacement: 5.3-6.2 Liter EnginesCylinder Heads: Cathedral Port or Rectangle PortRecommended Compression Ratio: 9.4.0-11.5:1Recommended Headers: 1 3/4" - 1 7/8"Recommended Stall Converter: 3000-3800Recommended Rear Axle Ratio: 3.42-4.30
https://ls1tech.com/forums/generatio...l#post17031139
The real concern is about part throttle driveability while still keeping the WOT torque manageable in an extremely light vehicle with small tires. That would be accomplished by minimizing the overlap and being careful not to have too late of an IVC (for the driveability side), all while having a healthy amount of intake/exhaust duration to push the powerband up @full throttle. The curve isn't nearly as peaky as the larger overlap, yet carries out consistently into the top end. It's a different approach than you'd do for a 3500lb+ car (or truck) with wide tires, setup for occasional 1/4 mile but intended to be spend more time street driving.
