To bore or not to bore Lc9 5.3
I have been measuring my cylinders but have not yet honed them. Trying to decide weather to bore it out or not. The measurement is consistently within 1 thou to 1.5 thou with the exception of 1 cylinder that is 3.5 thou out of round at 1" from deck. Mine is a 5.3 so a bore of 3.780 and I'm measuring 3.7865 to 3.788 at 1" down and half way down and at the bottom of bore. Meausred 90° at all levels so 6 numbers per cylinder. There is not much taper at all and not much our of round. The only question I have after reading some post is if 6 to 8 thou cylinder wear is too much for stock rings and pistons. I realize it will change when the head are torqued down and after honing. But would that little bit need to be bored? Or just hone and call it good with the stock pistons and new rings?
Yeah it's in my wife's suburban so I'm not spending a ton on it if I can avoid it. Lolit it has 255k miles on it and was burning oil and leaking oil like crazy and I'm amazed the AFM hasn't messed up in it. Initially I just wanted to do thw AFM delete but the cam bearings were worn badly so I pulled it to fix oil leaks and install all new bearings and rings.
That is exactly the plan
