New LS3 heads
Old Oct 18, 2023 | 12:39 PM
SRB's Avatar
SRB
Default New LS3 heads
Just bought a set of these Flotek LS3 heads from Summit: FLOTEK 276cc LS3 cylinder heads Cylinder Head, 68cc Combustion Chamber, 276cc Intake Runner, 92cc Exhaust Runner. Intake runners seem quite large, but I will be running them on an LS3.Here's what I have: 2cc forged dome pistons, standard bore, long tube 1 3/4 headers, aluminum fabricated intake manifold mid-range runner ,102mm TB, and a 226/238 - .600/.600 -113. I am hoping I can push enough air through these heads... naturally aspirated. Any thoughts?
Old Oct 18, 2023 | 01:03 PM
SlowTBSS's Avatar
Headers are a little small, those cheap fabricated intakes usually perform terribly as well.
Old Oct 18, 2023 | 05:14 PM
SRB's Avatar
SRB
It's going in a 2013 Camaro ss and it will never see a track and probably not even 100 mph. Just a fun hot rod to play with.
Old Oct 18, 2023 | 05:26 PM
Bspeck82's Avatar
What intake is it? Link?
Old Oct 18, 2023 | 06:25 PM
SRB's Avatar
SRB
Deepmotor Low Profile LS3 L92 102 Fabricated Intake Manifold + Fuel Ra I picked it up in Ebay for $300 used, it was cheap enough and the RPM range is what I am looking for 2200 - 6800.
Old Oct 19, 2023 | 12:47 AM
Bspeck82's Avatar
Factory ls3 will make more power
Old Oct 19, 2023 | 03:20 AM
xcomunic8d's Avatar
I’d return that intake run the ls3 or buy a fast lsxr. I’m running a tbss…one day I’ll buy a fast lsxrt.
Old Oct 19, 2023 | 07:24 AM
SRB's Avatar
SRB
I bought this Camaro for $7000 because the engine was skipping and making a noise, but I knew it wasn't the bottom end. When I took it apart, I found out it sucked an intake valve, destroyed one head, damaged the other, and beat the heck out of on piston top. Because the intake was stuck open it blew a bunch of heat up into the manifold and melted that runner so it's no good. I looked everywhere for a factory intake but can't find one. The car is in great shape with only 98K 2ss and a 6 speed manual trans
Old Oct 19, 2023 | 08:09 AM
slowride's Avatar
Well the backstory helps your cause and I'd maybe include that in the first post next time. I mean it will make power I'm sure, it's just been proven enough that the stock ls3 is pretty damn good in the typical hydraulic roller power range (under 7000) while most aftermarket intakes are not as good. I'd maybe have just replaced the piston, found a used head sent it, but what you are doing is fine and will work.
Old Oct 20, 2023 | 02:51 AM
xcomunic8d's Avatar
Didn’t know the background but oem ls3 and tbss intakes are really good unless you go to fast, imo.
https://www.ebay.com/itm/39483996689...Bk9SR6Dp_8DpYg
Old Oct 20, 2023 | 05:06 AM
tech8's Avatar
Post Test automation services Company in India
I’m just here for the SPAM…
Old Oct 20, 2023 | 05:49 AM
SlowTBSS's Avatar
In that case the heads are "too big" and it will be lazy for its intended purpose. This is a case of bigger isn't better.
LS3 intake will outperform this one. These fabricated manifolds typically don't make good power. There's a reason they're so cheap and something from Wilson is 4x the price.
Without some sort of adapters(not a fan of) the TBSS intake is a mismatch to the LS3 heads. Cathedral intake and square port heads.
Old Oct 20, 2023 | 05:51 AM
SlowTBSS's Avatar
I would look for OEM type parts and slap it back together with the cam. What's the piston look like with the dropped valve?
Old Oct 20, 2023 | 11:14 AM
Bspeck82's Avatar
ls3 heads are certainly not too big...
Old Oct 20, 2023 | 11:34 AM
SlowTBSS's Avatar
I didn't say LS3 heads, I said those heads being at least 20cc larger. IMO for what he's doing they're just not right. He would be better off with stock LS3 heads actually. I just think a 280cc port on something with this purpose will be lazy as heck.
Old Oct 20, 2023 | 11:37 AM
dawgs74's Avatar
New factory ls3 intake is under $300 dollars last time i checked….i bought one of those sheetmetal intakes years ago when i did my first 5.3 swap…10 years later and its still brand new un used in the box sitting in my garage, although i did end up using the 92mm throttle body, on both my ls3 intake and lsa supercharger and still running it to this day …..your heads will work fine and for what you plan on using the car for id say you gotta solid plan…..but i gaurantee your gonna pull that sheetmetal intake within a couple months and just replace it with a factory ls3 intake, did the fuel rails survive on the original intake? I wanna say i paid $225 for my ls3 intake from summit…those were pre-biden times though😂😂😂
Old Oct 20, 2023 | 10:45 PM
xcomunic8d's Avatar
agreed on the adapter. I was merely pointing out that both the LS3 and TBSS intakes are very good and hard to beat without spending major coin on an upgrade.
next time i will keep cathedral and rec port segregated. ​​​​​
Old Oct 21, 2023 | 07:57 AM
SRB's Avatar
SRB
LS3 intakes are $350 used on eBay if you can find them... Every dealership I called want's $900+ they are becoming rare as are the 821/823 heads. Just for kicks, look one eBay or call a dealership...
Old Oct 21, 2023 | 10:25 AM
Bspeck82's Avatar
You could sell that fab intake and pick up a fast 102 with long runners. Should be around 900 bucks. You will probably make well over 30-40 maybe even as much as 60 more lb ft of torque down low and as much as 15-20hp up top. Fab intake wouldn't make sense unless you are spinning to 75+. It would be such a dramatic change you would certainly need a retune.
This looks a lot like the sniper low profile manifold which had like a 4.5" runner. These manifolds could be great for boost or lots of rpm. Typically the shorter the runner the higher the rpm range of the manifold. I know it says 6800 but that's BS. Superchevy has multiple articles labeled intake manifold shootouts. Google it and read the results. You will get an idea of what short runner do with relatively mild engines.
Old Oct 21, 2023 | 11:26 AM
A guy here on Tech has a bunch of LS3 intakes with injectors and fuel rails for sale. $350 each. Good reviews. Here’s a link…your welcome.
https://ls1tech.com/forums/market/1967012
