0821 heads shaved .010 / pushrod length
then it started skipping and the dash lit up with check engine light, stable track, traction control, tire pressure... I think it's either the pushrods, blown head gasket or the camshaft sensor, maybe even the cam sensor pigtail. Haven't had time yet to do any diagnostic. I understand these LS engines have to relearn once a cam, crank sensor is changed, or a different cam is installed. I just went out and fire it up and only 3 cylinders came up to temp 325 degrees (at the exhaust port) the others were between 97 and 225 degrees plus I hear a slight ticking sound. I'm now 90% sure it's the pushrods. Any thoughts...
*I did change the valve spring from stock to single beehive .0625 capable and the valve spring install height is 1.80
* I did check the pushrod length and it came out to factory 7.4.
