VVT delete without cam change
A while back, I tried to determine how the VVT was setup for this engines. Anyone who has more solid understanding on this feel free to jump in.
I believe the phaser is advanced 7 crankshaft , and this supposedly results 3.5 advance at the camshaft (?).
Edit: Found the article stating the park position of the camshaft: https://www.underhoodservice.com/gm-...flow-pressure/
And this seems to track, because IIRC (been awhile), if you look at the factory VVT table it starts advancing around 4k rpm and reaches roughly 7* retard right at rated peak power rpm (basically making it 0*). So if the above is accurate, then total you'd have 5.5* cam advance.
Tossing it into the 'ole @Summitracing Cam Timing Calculator (courtesy of CamMotion): https://www.summitracing.com/newsand...ing-calculator nets a 28.5* intake valve closure. This would be pretty early, and likely hinder it's ability to build power especially above 5k rpm given it's duration and lift. Also the VVE tables would be incorrect.
I don't think running it that way would cause any mechanical damage, but it'd probably not drive very well. I wouldn't recommend it.
so am I reading this right there is no way a vvt engine works in a non-vvt truck without a cam swap? The vvt delete kits with a single bolt cam sprocket don’t time it correctly? I’m putting a 2011 engine in a 2007.5.
did you cam swap it? Or did you find a vvt delete kit that worked?? Thank!
Sure, it may not make top end power above 4000, but it’s not like these things make a ton of power up there in stock form with vvt enabled anyway.
is there any reason that wouldn’t work?
