I was hoping the threaded hole near the front of the block with the sensor and red&white wires in the picture would be suitable for a 2nd oil pressure sensor, but it doesn't seem to read anything. Is this just an oil return area?
(FYI - My rear block oil pressure sensor connects to a gauge; I want a second connected to my ECU. Yes, I know about the oil cooler bypass, but it is too close to my headers for a sensor there.)
It’s directly into the main oil passage off of the oil pump. You definitely have pressure there. I’ve circled the port here on a sleeved 5.3 block I recently sold. All LS blocks are the same in this regard.
Thank you! That is what I thought, but my Holley Dominator does not read any oil pressure from that sensor. Hard to see in my picture, but it is a 3-wire sensor. I can now concentrate on diagnosing it as an electrical or sensor problem.
Like Che70velle says...
I use that hole to pressure prelube all my LS's...
4.8 Oil Pressure (Oil) An oil pressure input is a standard feature on Holley EFI. A connector is installed that is plug-and-play with Holley 100 PSI pressure transducer PN 554-102. A different 0-5V transducer can be used, but the calibration must be set up as a custom sensor in the software. If these are not connected to a pressure transducer, the Fuel and Oil Pressure will read “LOW Err” in the data monitor. This will not cause any issues. A18 – Sensor Ground (Pin A) A26 – Sensor +5V Reference Out (Pin B) A20 – Fuel Pressure Signal (Pin C
Yup, pretty sure I have that Holley oil pressure sensor; but have never had a reading from it. I have the Holley fuel pressure sensor and that reads correctly.
For anyone stumbling on this thread in the future, the Holley EFI Pin A26 (Sensor +5) and A18 (Sensor Ground) also connect to the MAP and TPS; in total its Oil Pressure, Fuel Pressure, TPS and MAP.
If any of those sensors or the wires to them short out (ask me how I know), none of those sensors will read correctly; e.g. the MAP will read 15kpa. Interestingly the CTS and IAT will read 300F, causing the fans to turn on. Obviously the engine does not start.
I will add that the pressurized oil readings from there will read a few lbs higher than from the port where the OEM sender is located. Because this is pre-oil filter......
I use that port to pressure prime oil throughout a new motor, leaving valve covers off to see oil getting to every rocker. It can take 20 mins or so, rotating the crankshaft 90* every 5 min, 4 plus qts of oil and 60 psi of pressure in the oil tank. iCT and Autometer make nice 16mm to 1/8”pipe adaptors to screw into that port.
Shorting out the 5v reference is bad news. I am glad you got that sorted out.
Forgive my noob question, but couldn't you split the signal coming from the oil pressure sensor instead of using two sensors? I only ask because I'm going to be running into this same issue soon.
