“High” Compression 416
12.2:1 (may eventually mill heads down and get closer to 13.0:1) compression ratio. I’m going with Wiseco +5cc dome, Eagle H beam with ARP2000, and BTR 4” crank. (Yes, E85 only truck. It’s everywhere around me).
96 single cab truck. 6L trans, 5K converter. Wanting to build a stout street/strip truck. Probably rev to 7000-7200. Nothing crazy.
At end of day I know I can go custom grind but truthfully I wouldn’t mind keeping this a “off the shelf” type of build.
What intake do you plan to use?
113+4
intake will be a rod mod ls3 intake (as of now). 4000 stall. Heads are going minimum 66cc to reach 12.0:1 with -3cc piston. May go closer to 60cc for the added compression. May or may not port them this go around.
113+4
4.005 bore x 4.00 on mine, 66cc, -3cc Wiseco and .036 head gasket came out to 11.8:1.
luckily I rechecked my engine shop quote before purchasing. The +5 dome is 4.070 only. And my block needs 4.075. When we rechecked the only piston that would suite me is -3. The rest were like -18,-23, etc dish piston.
I’d be happy at 530-550 whp range and 500+ ftlbs at 4000-4500 range. Shifting around 7000-7200. Heads will be a dual .660 spring kit, titanium retainers, some nicer lifters and probably ls3 rockers with trunnions or shaft mount rocker.
I agree with 6L trans. That’s why I’m okay with shifting power curve to 4000+ range. With the gearing, 4500-5000 converter, and a decent gear it’ll still get out of hole just fine I believe.
https://www.summitracing.com/parts/f...make/chevrolet
