gen4 ls rod question
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1124/img_20240323_181748029_hdr_7f82a73b44cc99cef8d7de59657e0ff80182dc7b.jpg)
rods
I bought these gen4 rods and the rod bearing tangs are not the same.The rod on the left will put the bearing over the edge of rod since the tangs are at the very edge of rod.The rod on right is stock ls and you can see the difference in the tang location.Would I need a tangless bearing or is there something else going on.If its a bearing and you have experience with these can you post rod bearing part number..thanks so much
Got a part number on the rod on the left?
