05 cts v oil pan on ls3
Will the tray and pick up tube fit from the 05 cts v onto the ls3? I’ve searched can’t seem to find anything. I picked up a ls3 for my 05 cts v cause the ls6 timing chain gave out and destroyed everything. Or can I use the ls3 pan to go into my car?
Pans and pickups, except for dry sump versions, are all interchangeable.
Always use the pickup matched to the pan.
It shouldn’t fit. Two totally different pans. Changing pans isn’t. Big deal.
if they look different, Swapping lands is a must
will a ls3 oil pan clear and fit in a 05 cts v ??
really don’t want to take the pan off if it’s not necessary
