More performance from LQ9
Old Jul 22, 2024 | 11:50 AM
B58_3.0's Avatar
Default More performance from LQ9
Hello everyone, I am new to the forums. It’s been a while since I’ve been in the American auto forums. My grandfather recently passed and he left me his 2005 Cadillac Escalade 6.0 AWD LQ9.
it’s just over 100k miles in pretty good shape. I plan on using it as a family vehicle with some possible towing in the future.
I am aware that the transmissions in these need some up keep. Having that said is there anything any of you would recommend for this vehicle to get some extra torque/HP?
I plan on getting a better air intake mini-fold. Can anyone guide me into some headers and exhaust recommendations? Or some mods that would add me some extra HP that doesn’t require internal upgrades. Links and website information is highly appreciated.
THANKS!
Old Jul 22, 2024 | 12:10 PM
bthomas's Avatar
first things first, know a tune will be needed for all of this.
Tbss intake, 87mm oem tb, and a x-link or similar to drive the throttle body.
Replace the intake tubing with some 4” piping, and run a card maf. Commonly referred to as a 100mm maf.
You’ll need injectors almost immediately for any power improvements. Most will use the newer L9h e85 truck injectors as they are 50lb/hr and have good data to plug into the ecu.
headers are pick your favorite. Arh or kooks will give the best results, but they are the most pricey. Speed engineering is decent for the $.
A good torque converter would be a nice addition too.
Old Jul 23, 2024 | 04:39 PM
B58_3.0's Avatar
Is this what you're talking about? What do you mean by X-LINK?
https://www.glennsautoperformance.co...ails-injectors
https://www.hawksmotorsports.com/ls1...3-blade-style/
What would you recommend for torque converter stall speeds?? This truck is mainly going to be used to long trips and possible towing capabilities.
Old Jul 24, 2024 | 07:00 AM
bthomas's Avatar
Some info on the intake swap here
https://m.youtube.com/watch?time_con...OTExNywyODY2Ng
the Xlink is so the existing pedal and tac module will run the newer 90mm tb.
torque converter is best determined by the company you choose to make it. They will ask a lot of questions to make sure your getting what will work
Old Jul 24, 2024 | 01:08 PM
Jimbo1367's Avatar
  1. That intake setup looks like a good deal to me. No searching for deals. Just call them up. Remember to have your tune done though
Old Jul 24, 2024 | 03:23 PM
Full Power's Avatar
I have an LQ9. It's a Good solid 10 to 1 motor.:
Texas Speed "Low-Lift" .551" 212/218 duration cam REALLY woke it up.
You said 'no internal mods' but the factory cam profile is a hard limit on airflow at amospheric pressure.
Doesn't matter how big your intake TUBE is, if the valves are only open .460" for 196 degrees your torque is falling after 4000
Valve Springs, Camshaft, gaskets and a few hours LABOR going to give a lot more results per dollar than aftermarket exhaust system, cosmetic "Cold Air Intake " toys.
Old Jul 24, 2024 | 05:38 PM
A bit late now, but isn't the LQ9 a Gen III??
Old Jul 24, 2024 | 06:53 PM
68Formula's Avatar
Yes. Your point?
Old Jul 24, 2024 | 08:12 PM
Originally Posted by 68Formula
Yes. Your point?
It's in Gen IV Internal, not Gen III Internal.
Juuuust checking.....
Old Aug 1, 2024 | 06:34 PM
gnx7's Avatar
I know some parts of AZ have strict smog laws... so make sure your mods will still get the green light unless you know a guy
