Molnar Rod bearing clearance
If I order STDX, I should be able to get to .0027. That's not too loose for a DD with a small cam and about 14psi from a D1SC?
Mains came in at .0022 across the board. Aluminum 6.2L.
Exactly what I am doing. Bought a rod vise, dial bore gauge and micrometer to hopefully ensure this is the last time this particular motor comes out of the truck. Measuring every journal and bearing diameter to ensure proper clearance across board.
Thank you again!
