New technology for resleeved blocks
It's crazy how thin the material supporting the larger sleeves is on the stock block, but I've been watching several guys with resleeved 427's making a lot of power with several laps at the drag strip on them issue free.
I think this Steve Morris block filled would be able to handle a sh*t ton of power but at that price you would have to be simply wanting the bragging rights of doing it with a stock block.
Best bang for the buck out there is the Concept LSR block.
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Offhand I only know of one class (Holley LS Fest Stock Block) that mandates a stock 4 bolt block. The class only pays out $2-3K to the winner.
Also, if you don't want to comment directly about his design that is understandable, but I would like your input on where you normally see sleeved blocks fail. It seems like the mains are still the weak link and is why the LC9 block is preferred for resleeving correct?
The longer head studs seem like a benefit, but the rest of it may be adding additional cost without actually addressing the weak link with resleeved blocks.
That's interesting, why on earth would they make 2 versions like that? I've got a few cores here I need to look at closer.
It also makes me suspect they found a problem with version one before any are even in the wild yet if they are already on to version 2.
Why bring something to market that hasn’t had real world testing ? He does amazing things but also has lots of problems initially. That’s part of the process but I don’t want to be a test subject. lol.
He also walked back and said if you really want a wet deck they will drill holes where the head gasket has them.
Yes, at this point you would be a Guinea pig.
Block number one didn't even have the sleeves installed in it yet when he came up with design 2.
Im sure morris would take care of you if his block failed but what about all the other parts it took with it when it failed?
All of that and still do not get priority main oiling in all of this that aftermarket blocks provide which I believe they still meet OEM block architecture for most classes. I feel like most classes just state no billet blocks.
The Deihl brothers just proved out my direction in this last Drag Week that Steve did for them. Dart block, dry decked block/heads, 1/2 studs, hooped, and parallel cooling.
