LS valve lengths
Old Oct 6, 2025 | 10:48 AM
RonSSNova's Avatar
Default LS valve lengths
Hey guys,
I picked up a set of valves that were supposed to be for LS heads. NIB and were dirt cheap.
2.08/1.60 8mm stem LS round locks.
Problem is they are 5” long.
LS are 4.9” correct?
Were there any LS valves 5”
long?
Old Oct 6, 2025 | 12:24 PM
RB04Av's Avatar
Yes stock ones are various lengths near that; from 4.87x to 4.92x. I don't know of any that are 5" butt that doesn't mean there aren't any.
Aftermarket ones might be available in any length, usually longer than stock, to accommodate different configurations. Longer ones are usually used to allow bigger springs which in turn are to allow more lift before coil bind. .100" long is pretty common in engine building in general.
Old Oct 6, 2025 | 05:31 PM
RonSSNova's Avatar
I understand all that. It would take taller stands, longer pushrods etc to reestablish correct rocker wipe. If used in most LS heads.
If I would have had calipers with me I wouldn’t have spent the $100.
Old Oct 6, 2025 | 05:54 PM
Keith's Avatar
Hey guys,
long?
Sbc valves?
https://www.airflowresearch.com/afr-...5.000-oal/p486
Old Oct 6, 2025 | 06:19 PM
RB04Av's Avatar
SBC valves are 11/32" dia, 4.911" long.
​​​​​​​Generally so, yes. Not a slap-together.
Old Oct 6, 2025 | 06:59 PM
RonSSNova's Avatar
They were actually installed in SBC AFR heads but never run.
Maybe he just couldn’t figure out the correct keeper/retainer combo to work with his rockers?
I just know him from the drag strip. And incorrectly assumed he knew what he was talking about.
Old Oct 6, 2025 | 08:25 PM
RB04Av's Avatar
Yeah the 8mm LS dia stems have become popular in aftermarket SBC heads; lighter weight and all. None of that is stock though of course.
Old Nov 11, 2025 | 10:10 AM
G8 Drew's Avatar
I know the LT motors use taller valve springs. BTR has LT 1515 springs to set at 1.95”. With the rocker tip higher up you need to measure for a shorter push rod. How big a lift cam are you planning on?
Old Nov 13, 2025 | 03:30 PM
RonSSNova's Avatar
I simply bought these thinking they were Gen 3/4 valves. Spares just in case.
so at this point I have no use for them
