Help Me Personally Build A 400+ CID Engine
To start, I need a block. I’d love to know what everyone’s opinion on the best one for the money is. I want something that I can order finished, that is ready to accept bearings and the rotating assembly, but isn’t crazy expensive like an LS7, LSR, RHS, etc.
The second thing is a balanced rotating assembly. What have some of you used successfully out there? This is an NA build, so I would like to keep the rods and pistons light but strong.
Thanks in advance for your thoughts and experiences. This should be a fun build, and I’ll be sure to document the process here.
If you just want a 400+, go LS3 block with 416 stroker kit and LS3 heads. Budget with later probably wanting and going with above 427.
Start with a good foundation for thr 400ci build. If it has to be aluminum then a 6.2 block would be the cheaper route over a resleeved 5.3 aluminum block, however the resleeved block by R.E.D. would be a solid foundation.
BTW my 01 SS has all of the creature comforts and a race weight of 3,840. That's an iron block build with tubular suspension and aluminum wheels as my weight reduction. Had I kept the aluminum driveshaft and the stock 10 bolt I would have came in even lighter and another thing..600 rwhp naturally aspirated is not a cheap build.
Stroked it to 427 cubes with a Manely 24 tooth crank stroker kit.
With a built 4l60E auto It did 495 rwhp on the chassis dyno.
Small to medium size cam. 225I/230E .610 114 cl.
Stock LS3 heads.
Drove like a stocker until to punched it.
To achieve your goal, you will need aftermarket heads, and probably intake as well. Having a manual transmission makes it easier, but 600 at the wheel is a lot for an NA build. The small bore LS7 heads would make it easier though. It just depends on how much you are willing to spend.
Not to mention an intake that will flow that and fit under a stock cowl! There is a lot of cost to one that fits that build!
Surprised no one else has sobered up the OP yet
600 RWHP N/A will never be relatively affordable nor is it easy to accomplish. It takes a solid designed combination with good parts to get there. If it was relatively affordable and somewhat easy there would be alot more people driving 600 RWHP vehicles.
If you crack 600 wheel NA in an LS pump gas street engine your probably in the top 5% of most of the N/A builds out there....open to debate but I bet that's a pretty close guess if you looking at ALL the potential builds that people embark on
To truly get there you will need cubes and likely more expensive LS7 heads if you want anything remotely streetable and that complete combination will cost you every bit of 20K if you build it yourself....more if you source it somewhere and have to pay for labor etc.
This hobby has gotten alot more expensive in the last four years unfortunately....its best to go into a new build with somewhat realistic financial expectations and somewhat realistic performance expectations.
550 is more doable but even that isn't an affordable venture....still requires a stroker engine and a good top end. Machine work is pricier also these days....it all adds up rather quickly
I would love to help you out but I felt it was important to reset your expectations a little. You won't touch anywhere near 600 wheel without spending at least 20K if your starting from scratch.
My advice is reset your expectations a little and/or your budget....hopefully there is a compromise of the two that leaves you with something you can work with
Cheers,
Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
To build it that cheap, I had to find surplus parts from places like Facebook Marketplace. You can’t build it that cheap by ordering everything brand new from places like Summit or TSP.
If you really want a 600 whp N/A engine, it can be done. But as Tony said, you need to be realistic with your budget and goals.
Cheers,
Tony
I’ve been going through a ton of build threads that have dump and/or track results. @Tuskyz28 cookbook is a great thread. Interesting to see the M6 cars above 3500lbs that reach 130mph. There are some sub-427 engines with cathedrals that do well. @Tony @ Mamo Motorsports also has some great examples of cathedral builds that should reach 550 wheel in my setup. Not sure it’d make sense to pay for a build that isn’t going to completely satisfy me, though. Especially since it’s from scratch, and the extra cost to go to the next level is relatively low from that point. I can’t imagine building a 416 only to want more in two or three years. That sounds like me, though! What a waste of $$$.
My other problem is that I really want to build this thing. I get as much satisfaction from putting stuff together as I do using them. Shoot, maybe more to be honest. That only gets amplified if the end result is also great. I have a number of decisions to make before proceeding, but I’ll keep this thread updated as I make progress.
