4l65e?
Old Aug 11, 2004 | 11:30 PM
1fstGM's Avatar
Restricted User
How is the 4l65e holding up. How much RWHP is your car putting out.
Old Aug 12, 2004 | 11:33 AM
patriot68's Avatar
a 4l65e is beefed version of the 4l60..65 has heavy duty input/output shafts, 5 pinion planets, and heavy duty shell..if you know how to build trannys you can buy the parts and put them in a 60....
4l60/65e is electronic it has no vaccum modulator
Old Aug 12, 2004 | 12:52 PM
WhiteDiamond's Avatar
FYI...It is a very poor idea to purchase trannies based on somebody's horsepower claim. Horsepower has very little to do with auto trannies and how they hold up. Get a input torque rating on the tranny before you make decisions, that is the number that actually means something.
Todd
Old Aug 13, 2004 | 10:07 AM
technical's Avatar
Originally Posted by NO-OPTION-2002
If you'll notice on the right side in the applications they show several BMW's that use the 5L40E. I guess that says something for our "lowly American cars"
GM has been building BMW's auto's since BMW started offering automatics in the late 80's. I believe they were variants of the TH350.
If memory serves the 5L40E, at least in the beemers, weighed ~250lbs. I can't say that I remember the exact weight of the 4L60 and 4L80, but I'm guessing the four speeds are much lighter than that.
GM should start thinking about putting a five speed auto in the C6. It would make a hell of a difference.
Old Sep 12, 2004 | 04:51 PM
ssierra's Avatar
200r-4..........weak compared to the 700r-4, 700 is pretty much a 4l60.
4l60 is pretty much a th350 w/ overdrive, same gear ratios
4l80 is pretty much a th400 w/ overdrive, same gear ratios
Old Sep 12, 2004 | 08:41 PM
DeepBlueZ's Avatar
right about the 400-4L80, wrong about the 350-4L60.
TH-350...
1st = 2.52:1
2nd = 1.52:1
3rd = 1:1
700-R4/4L60/4L65(E)...
1st = 3.06:1
2nd = 1.62:1
3rd = 1:1
4th = .70:1
By Brett Foote | 2026-06-04 05:00:17
