z07
Old Aug 7, 2004 | 03:29 PM
52172's Avatar
Default z07
what is the latest info on whats under the hood on the 06 z07 is it a 427 or a 6 ltr I think we all already know it will have 3v heads. What type of bottom end are we looking at?
Old Aug 10, 2004 | 05:03 PM
Chicago Crew UnderBoss's Avatar
The 2006 Z06 will still be called a Z06 not a Z07 (but the engine in the new z06 will be called an LS7 motor). Also, for my money the biggest cubes in my opinion that the LS7 motor will be is 6.4 liters and the most power we can hope for is 500 ponies at the crank (and yes, all because GM still wants to play second fiddle to MOPAR with its big cubed and powered 502c.i.VIPER MOTOR)!!! GM needs to step up to the plate b/c they have been behind MOPAR ever since the dam VIPER cam out in 93 or 94!!!!
Old Aug 10, 2004 | 05:36 PM
1jfuddle's Avatar
Werd.
That is exactly what I have heard.
zo6-ls7-'bout 6.4-24 valves-'bout 500 ponies
Now the Blue Devil on the other hand, that is where, if it happens, the 7.0 liter will be.
Old Aug 11, 2004 | 08:15 AM
SStolen's Avatar
I think Viper came out in 91??
Old Aug 11, 2004 | 10:01 AM
Armageddon's Avatar
...with cheese.
Originally Posted by 1jfuddle
Werd.
Old Aug 11, 2004 | 10:09 AM
02WS6Bird's Avatar
ive seen vipers get whiped by the Z06's of 2day....so i dont thin k GM's far behind....also the Vipers i believe are overrated and pretty weak for a V10!!
whats the Blue Devil?
ive also heard the Z06 will be 6.4L 24 valves and about 500 horses as well
all hail LSx motors
Old Aug 11, 2004 | 10:47 AM
Shoulder Shaker's Avatar
I guess that shoots down the WRONG INFO that I was getting. 575 hp 427. Maybe I will just keep the SS and do a little more upgrading to the motor and I will be right there.
Old Aug 11, 2004 | 11:02 AM
01_SuperSlow's Avatar
The blue devil is a sub-3000 pound C6 chassis Corvette running a 7.0 liter making anywhere from 700 to 725 horsepower with a cost of $100k+. If it is produced at all, it'll be several years after the 2006 Z06.
Old Aug 11, 2004 | 11:43 AM
86SWB's Avatar
Any links to the Blue Devil?
Old Aug 11, 2004 | 11:48 AM
DanSSull's Avatar
I believe the Viper is better personally, although you have to add in the price factor got to bless the Corvette there, for just alittle more you'll take down the V10 and taking down the big boys even stock now with the C6. Blue Devil I want to see pictures of too though friend told me about it.
Old Aug 11, 2004 | 11:49 AM
hellbents10's Avatar
LS1Tech Sponsor
I would like to know more about this supposed blue devil also. GM has done a fine job with the z06. It may not have the hp or the cubes that the viper has but it does everyhting better then the viper.
LS1Tech Sponsor
.....for less money.
Old Aug 11, 2004 | 12:31 PM
Raptor99's Avatar
I heard the Blue Devil was "only" getting 625hp...
Then again, that was quite a few months ago.
Old Aug 11, 2004 | 01:33 PM
02WS6Bird's Avatar
Raptor did you run that 12.97 b4 or after the stall?
Old Aug 11, 2004 | 01:59 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Think about 500HP in a 3400-3500 lbs car vs a 500HP car that weighs 3000 lbs. Thats not second fiddle to a Viper. 600-700HP in a sub 3000 lb car is better than 650 in a 3500-3700 lb car. That is on par with any of the Supercars on the planet.
Old Aug 11, 2004 | 02:32 PM
BlackTA's Avatar
I just checked the Dodge website, and it says the Viper SRT-10 has a curb weight of only 3380 lbs. Thats crazy, how can such a huge car, with a huge engine, and huge wheels weigh less than 3400 lbs? must be made of foam.
Old Aug 11, 2004 | 02:35 PM
T/A-Speedfreak's Avatar
The latest magazine I read said that chevy was unable to reach the 500hp mark so instead they reduced the new Z06's weight by 300#s. That means it will weigh under 3000#s.
Old Aug 11, 2004 | 03:21 PM
Blakbird24's Avatar
Restricted User
With all the info I have, it will be a 6.6l motor. Which is 405ci I believe.
It will be 500hp or better, fairly well torque biased. Plus the Z06 will be way lighter than the Viper, so I don't see that being a problem.
Old Aug 11, 2004 | 03:50 PM
GA_Driver's Avatar
I managed to google this—
Some C6 pix, while we're at it— http://www.atomicred.com/jaek/vette/yelC6/
Old Aug 11, 2004 | 04:54 PM
GMCtrk's Avatar
wow was GM trying to copy the viper when they designed the c6?
