GM Prototype GTO Engine Specs
Old Sep 3, 2004 | 12:52 PM
SlickHolden's Avatar
Gee Can they make the rear any fatter ?
This car would look much better with the Judge bonnet scoops and engine.
Attached Thumbnails GM Prototype GTO Engine Specs-2468088-aych-20es-20veea.jpg   GM Prototype GTO Engine Specs-2468088-aych-20es-20veeb.jpg
Old Sep 3, 2004 | 01:24 PM
TanRchy's Avatar
maybe its just me, but, i think the exhaust duration is so big b/c it will be used with the new 3 valve head. any1 confirm?
Old Sep 3, 2004 | 01:49 PM
Z06Cam's Avatar
That's the exact thought I had. With 2 intake valves and only one exhaust valve, I would think you would need a lot more duration on the exhaust side to compensate.
Old Sep 3, 2004 | 01:57 PM
TanRchy's Avatar
i like the idea, i dunno bout the design structure though....
Old Sep 3, 2004 | 02:00 PM
TriShield's Avatar
Wouldn't heat create havoc with the induction system set right over the engine?
Old Sep 3, 2004 | 02:03 PM
Ryan23silverado's Avatar
J-Rod you are right about that manifold. The LS2 looks a lot rounder on the bends. That one pictured looks like a FAST in the way its runners appear. Geez...now I have to wait even longer for a new manifold
Old Sep 3, 2004 | 02:35 PM
Cobraeater's Avatar
Lightbulb
The manifold looks exactly like the ls7 intake.
https://ls1tech.com/forums/showthrea...ght=LS7+Intake
Looks like that concept GTO has the 6.4 ls7 in it.
Old Sep 3, 2004 | 02:58 PM
granitemonkey's Avatar
Things that make you go hmmmm, on a side note that Goat sounds mean as hell.
Old Sep 3, 2004 | 03:45 PM
Cheatin' Chad's Avatar
That looks identical to the Intake the on the CTSV cars in the Speed GT series.
Old Sep 3, 2004 | 04:10 PM
Another_User's Avatar
I doubt that, since it says "389" right in front of the engine. That is almost definitely the cubic inch displacement number.
Old Sep 3, 2004 | 04:12 PM
Z06Cam's Avatar
I think you're correct. Either that, or it is a custom motor using some LS7 parts, like the intake and heads.
There are some guys on the various Corvette forum who are absolutely CONVINCED the new Z06 will be a 7.0L. I personally think that's wishfull thinking. Anyone care to comment?
Old Sep 3, 2004 | 04:15 PM
  #32
02RedHawk's Avatar
Its an LS7 intake w/ LS7 heads.... Casting number 8452.
The new Z06 is NOT a 7.0L. Guaranteed.
Old Sep 3, 2004 | 04:19 PM
  #33
Z06Cam's Avatar
389=~6.4L, no?
Old Sep 3, 2004 | 04:20 PM
  #34
Z06Cam's Avatar
Cool! Where did you get your info from? And don't say "a good source." :p
Old Sep 3, 2004 | 04:56 PM
  #35
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
The motor in the concept GTO has a lot of parts from the Pratt & Miller CTS-V racing team FYI.
Old Sep 3, 2004 | 04:57 PM
  #36
389=~6.4L, no?
My bad...I keep forgetting how far GM rounds up. Like our "5.7" liter. Which is not really that close at all.
Old Sep 12, 2004 | 12:22 PM
  #37
Mr1970Chevelle's Avatar
From: Flint, Michigan (Yeah, the little "F" you might find on your VIN)
Originally Posted by horist
sounds nice... but doubt it'll happen anytime soon.. can't get too close to corvette territory....
You never know... look at the 70' LS6 Chevelle... Stranger things have happened.
Old Sep 14, 2004 | 03:31 PM
  #38
soslo's Avatar
4.135" bore? That is super sweet. We can have 430 cubes (7.0L) with a 4" stroke...
Old Sep 14, 2004 | 05:04 PM
  #39
BigPlanTransAm's Avatar
not too close to corvette territory? i dont know about you but i've seen/heard ALOT more Goat commercials than corvette commercials.
if they do it'd be aswesome but concepts usually dont go into production the way they're shown
Old Sep 21, 2004 | 12:14 PM
  #40
Juiced's Avatar
it's a special projects car, expect alot more from the LS7 i saw a gm built Twin Turbo Escalade, it dosn'r mean it will ever go into production but they like to do this to get the public all riled up
