GM Prototype GTO Engine Specs
http://www.cheersandgears.com/forums...showtopic=5316
Specs as posted there as well:
All engine parts are from the Gen IV small block family
Engine Displacement: 6.4L (389 CID)
Bore: 105.03mm (4.135”)
Stroke: 92.00mm (3.622”)
REV Limit: 7000 RPM
Peak Hp: 575 Hp @ 6800 RPM
Peak Tq: 500 Lb-Ft @ 5200 RPM
Compression Ratio: 10.5:1
Cam Shaft: Custom GM Hyd Roller
Valve lift: 15.75mm (.620”)
Cam Duration Int: 232 deg @ .050” Tappet
Cam Duration Exh: 272 deg @ .050” Tappet
90mm Throttle Body
Dual Mass Air Flow sensors, Cold air induction system
If you read the whole thread you see other links for additional pics.
--JMarsa
Anyways, you can't make a MAF too big, or it won't read poop. Plus the cool part is you could use two MAFs for error correction on each other. Much more efficient.
^-- Exhaust doesn't look right for .050"! Other than that, sounds like a sweet power plant.
Josh
What about the transmission of this car?
Thanks
Video of the car running
http://www.ultimatesimcentral.com/gto_exhaust.MPG
