IRS for f-bods
Old Oct 24, 2004 | 07:43 AM
cueball's Avatar
Default IRS for f-bods
I was thinking, would the IRS for the GTO fit the F-body cars with min.
modifications to the F-body?
just something for you guys to think about trying.
Old Oct 24, 2004 | 08:27 AM
Patrick G's Avatar
LS1 Tech Administrator
Is your goal for better handling or smoother ride? It certainly couldn't be for decreased weight or better drag racing launches.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Oct 24, 2004 | 08:59 AM
cueball's Avatar
not for me, i was just wondering, i remembered
some other people asking about the IRS from the corvette, thought the IRS from the GTO would be easier to install than the unit from the vette.
just a thought, trying to get some opinions about it.
Old Oct 24, 2004 | 10:32 PM
slow's Avatar
i don't think its possible to do.
in reality, its not something that can be done with good results, without major fabrication, look at the other chassis that dates back 25 years and see how the bolt in irs works (mustang)
Ryan
Old Oct 25, 2004 | 09:59 AM
Squat13's Avatar
Ryan
Im sorry but thats just the wrong attitude. Ive seen a C3 IRS under a 73' Vega Hatch back with two 4's on a tunnel ram stick out the hood. The thing would just squat and GO.
I just think you dont know how to weld and have no imagination. Cutting up cars and peicing them together is what this hobby is all about. Thats how it started, with Tommy Ivo sticking a 401 NailHead Buick V-8 on a 32' Ford Model A Frame with a 27' Model T Body.
Any way if I were trying to stick a IRS under the rear I would do what all the 50- something "Diaper Rod Rubbers" do and buy a IRS system aftermarket.
Old Oct 25, 2004 | 12:49 PM
Phoenix 5.7's Avatar
the gto has a really complicated IRS from what ive seen.
Old Oct 25, 2004 | 06:40 PM
ChiefBrody's Avatar
http://www.transamgta.com/FireFox/
It was done before, so with a little imagination it could be done.
Old Oct 25, 2004 | 10:17 PM
Yeah with factory money.
Old Oct 27, 2004 | 08:48 AM
firefighter's Avatar
My understanding in the beginning when they brought the GTO out was the diff was suspect. Prolly one out of a C5 would be better. There are also companies out there that put a full C5 suspension under a old '55-'57 shoebox so anything can be done if you want to.
Old Oct 27, 2004 | 08:55 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
The stock GTO IRS is very prone to breakage. Most Aussies put a spool in the more serious cars...
Old Oct 27, 2004 | 10:00 AM
SSCamaro99_3's Avatar
http://www.quarter-mile.net/images/I...IRS_index.html
Old Oct 27, 2004 | 10:21 AM
TheBlurLS1's Avatar
That's what she said...
rad rides by troy has a 32' ford with all wheel drive.
i think it has somthing like a c5, only in the front!! they call it the quadradeuce, i think its pushing like 650 hp. a little imagination, skill, and alot of money can get you anything.
Old Oct 28, 2004 | 07:24 PM
cueball's Avatar
thanks for the reply guys
Old Oct 30, 2004 | 11:47 PM
drmotorhead's Avatar
If you are going to go to the trouble of an irs conversion for an fbody, I would use a C5 rear over a C4(or anything else). It has the tranny in the back, which improves weight distribution. You might as well grab the LS1 if your fbody does not already have one. Then again, if you do both, it would probably be cheaper to just get a C5. You can get a good one for mid to low 20's these days.
Old Oct 31, 2004 | 10:30 AM
vettedude's Avatar
no it is a S-10 setup uop front, with the C5 rear end out back...
Old Nov 4, 2004 | 07:34 AM
beertestr's Avatar
ANYTHING can be done, but why? On a road course an F-body with the right SLP suspension parts, better front brakes, and good track rubber can run pretty close to a C5 (not Z06) on track rubber. I've seen it done.
Believe it or not, the stock axle is the lightest OEM suspension setup out there. Yeah, there is more unsprung weight than an independent, but the total mass compared to an IRS is usually less... and cheaper.
That said, I have driven both an F-body and a GTO at the limit, and the GTO will always feel more planted, the F-body takes more attention if trailbraking into a bumpy turn, the axle likes to tramp around, and you need a little more steering input to keep the car under control, but it has a higher lateral g capability. I ran my GTO with some retired A-sedan F-bodies (3rd gen, but same suspension as 4th gen) and it they could flat out corner me.
On a tight back road, with less run off room, I always seem to run the f-body a little easier than the GTO. YOu just can push the GTO closer to it's limit and not worry about the tail dancing around..
I am not a big fan of F-bodies <duck> on the street, but they are damn fun track cars..
