LS2 402 short block at SDPC!
Old Nov 30, 2004 | 01:24 AM
amwellls1's Avatar
yipee I can not wait to get one of these, looks like I got to start saving my money
Old Nov 30, 2004 | 01:31 AM
Ryan23silverado's Avatar
Good job man! You will definitely get the jump on others from doing this. The pricing for everything that will include sensors etc. seems reasonable too I hear a promotion Kris
Old Nov 30, 2004 | 03:33 AM
2MuchRiceMakesMeSick's Avatar
WOW Very nice price, I just have to save up the money.
Old Nov 30, 2004 | 06:39 AM
Billiumss's Avatar
Great price!!! Those will sell like hotcakes... Any warranty on it?
I might have to sell my 6.0L Iron block and jump to the LS2 down the road.
Why can't you just reuse your stock knock sensors and extend the wires? Did I miss something here, please explain...
Bill
Old Nov 30, 2004 | 09:06 AM
RX-Ben's Avatar
The LS2 knock sensors are in a different place and the computer looks for a different freq. for know because of the different location.
Ben
Bill
Old Nov 30, 2004 | 11:34 AM
Billiumss's Avatar
ok, I know that they are on the outside, but can you just adjust for them in LS1 Edit or HP Tuners?
How can the "Frequency" of knock change from the engine, Knock is knock. I could see this being an issue if we used LS2 sensors on ours cars now.
Having them there and being somewhat useable is better than not having them at all... Someone will figure it out....
Old Nov 30, 2004 | 11:37 AM
mySStery_machine's Avatar
Sound travels through the metal and will cause a different pitch and that is what the computer is picking up on. If the sensor is clear across the block the sound will be registered differently in the computer therefore it will not be able to compensate for that. I think that is the right answer at least and if I am wrong someone please explain the right reason. This one makes sense to me though as for how the sensor works.
Old Nov 30, 2004 | 12:02 PM
GrannySShifting's Avatar
Kris, PM me please I have some ?s for you
Old Nov 30, 2004 | 12:48 PM
TAF Motorsports's Avatar
looks like i may be selling my LT1 stuff and move to the GEN III dark side
Old Nov 30, 2004 | 01:31 PM
GuitsBoy's Avatar
That's the GEN IV dark side
well.... Gen 3 and a half anyway.
Old Nov 30, 2004 | 01:33 PM
GuitsBoy's Avatar
Kris @ SD ... simply amazing. Great parts and great price. Id hate to be SLP right now. Even more than I'd normally hate to be SLP.
Old Nov 30, 2004 | 03:41 PM
  #32
Old Nov 30, 2004 | 07:14 PM
  #33
Dracus's Avatar
Absolutely awesome. My winter plans just changed. Time to start saving.
Old Nov 30, 2004 | 07:34 PM
  #34
pkincy's Avatar
Originally Posted by DrkPhx
Kris - How about flat top pistons with valve reliefs? I would like 10.9 to 1 compression.
You might want to run a CR calculation. With a normal gasket and only -2 cc reliefs you will be surprised what CR you will end up with starting with a normal 59-64 cc sized chamber.
Remember CR is the size of whole volume divided by the compessed volume. And when the whole volume gets lots bigger (stroker motor) you will get up in the 13s very quickly.
My rough calculations call for 76 CC of compressed volume on a 402 to get in the high 10s for a CR. So we need around -12 to -15 cc dish if we have a 59-64 cc chamber.
BTW, Kris can order custom JEs for anything you want. It is only money after all <g>.
Perry
Old Nov 30, 2004 | 07:42 PM
  #35
JZ'sTA's Avatar
Great price.
Looks like a WINNER.
Old Nov 30, 2004 | 08:03 PM
  #36
phoenix's Avatar
so will my wire harness work with this motor? will my cam fit? damn i need to get a 2nd job
Old Nov 30, 2004 | 08:30 PM
  #37
Beast96Z's Avatar
Yes, you have to extend you cam position sensor harness to fit into the new location on the timing cover and that should be it. Like they said earlier, for the time being, the knock sensors have to be turned off and your cam will work with the stuff he send in the package.
Old Nov 30, 2004 | 08:40 PM
  #38
waterbug1999's Avatar
Just curious... But with a nice set of heads and intake, exhaust, etc.. What kind of power do you guys think it will make at the wheels?
Would there be any advantages/disadvantages for and LS2 block versus and LS1 block.. Given all other parts the same?
Old Nov 30, 2004 | 08:52 PM
  #39
DrkPhx's Avatar
Perry
Thanks for the info. I based it on the fact the stock LS2 has true flat top pistons and LS6 heads with 65 cc combustion chambers that comes 10.9 to 1.
I don't know the compressed thickness of the LS2 head gasket, but assumed it was the same as the LS1
Old Nov 30, 2004 | 08:59 PM
  #40
Gino.. are you looking into getting one too?
