LS7 in Z06 PICS INSIDE
i feel C6 daily driver great fun factor well worth it and powerful (kinda like a camaro)
Z06 aggressive supercar look definite fun factor (kinda like the T/A compared to Cammy witht he aggressive sharp look rahter than smoothe and clean)
Sweet MOther of God! I need one Black on Gray please!
But how much? 70k? Worth every penny. I was just reading an article today and it showed the specs of a regular C6 vs. a 911 Carrera 3.8 and the Vette was faster AND cheaper. Now the ZO6 is goin after the big boys HELLS YEAH BIACH!!!!
0 -> 60 in 3.8 sec.
Top Speed 200 MPH
2,900 #'s
5.7 #'s/HP
Chassis & Suspension development by Pratt & Miller,
Aluminum Hydroformed frame produced by DANA
- 345/30x19 Rears
- 6 piston Front, 4 piston Rear Brake Calipers
- Cross Drilled (cast and camfered) Rotors (possibly Brembo)
Engine Development by KaTech
To be hand built by new HP Engine Plant
LS7 427ci/ 7.0L. 500HP/500 Ft Lbs (512 HP derated to 500HP)
- 2 OHV (3 OHV not necessary for target HP)
- Raced based CNC ported Aluminum Head with 70cc chambers
- 11.0:1 CR
- 46 mm (1.81") Titanium Intake valve
- 41 mm (1.61") Na filled Exhaust Valve
- 104.8 mm Bore (4.125") , 101.6 mm Stroke (4.0") Aluminum block
- Forgrd Crank
- Forged 6 bolt main Bearing Caps
- Titanium Rods
- Cast Aluminum Flat Top Pistons
- 0.591" Lift Cam (15 mm)
- Dry Sump
- 90 mm Throttle Body on Composite manifold
- Ram Air
3485lb/550hp = 6.34lb/hp
C6 ZO6:
2900lb/500hp = 5.8lb/hp
Add to that the ZO6 has a slightly lower 1st gear, and costs...what...HALF of what the GT does? I'm really starting to feel sorry for Ford.
Just kidding. The GT is a sweet car anyway.
! 3485lb/550hp = 6.34lb/hp
C6 ZO6:
I think the Ford GT is pretty seriously underrated though... isn't it more like 500 at the wheels?
