LS7 in Z06 PICS INSIDE
Old Dec 9, 2004 | 10:52 AM
70 TA's Avatar
Default LS7 in Z06 PICS INSIDE
Found some LS7 pics <says 7.0L>
Attached Thumbnails LS7 in Z06 PICS INSIDE-z06-20rim.jpg   LS7 in Z06 PICS INSIDE-z06-20race.jpg   LS7 in Z06 PICS INSIDE-z06-20engine.jpg   LS7 in Z06 PICS INSIDE-z06-20side.jpg   LS7 in Z06 PICS INSIDE-seat.jpg
Old Dec 9, 2004 | 11:03 AM
Damage Inc.'s Avatar
Sweet Cheeks
Dicked. A ten second car, with traction, right off the showroom floor.
Old Dec 9, 2004 | 11:07 AM
Diolar Magnum's Avatar
RIP April 14, 2008
From: the land where cars repeatedly hit my bumper when I'm in the store...
woooooooo wooooooooooooooooooooooo but whats with the wimpy side scoop????
anyway f'ing hot vette. the thumbnail of the engine bay shows yellow covers but the pic is red...?
hottttttt
Old Dec 9, 2004 | 01:11 PM
70 TA's Avatar
Just think what a more agressive cam and some tuning will do to wake this up.
I'm still a bit hesistant on the specs like the titanum rods and the lift profile on the cam and chamber size yada yada.
This Block, heads and intake will be a great starting point for a beast.
It'll be interesting to see what quality of crank forging it gets and whether it does goet exotic rods. My opinion is that money can be better spent elsewhere then on titanium rods.
Old Dec 9, 2004 | 02:42 PM
epic's Avatar
I'd take one.
I still wish they would have made a more agressive front, or atleast shaded those damn headlight enclosures. God that yellow behind the headlights just bugs me.
Anyways, I'm glad that the 7.0L is a reality.
Old Dec 9, 2004 | 03:05 PM
pdd's Avatar
pdd
sweeeeeeet
Old Dec 9, 2004 | 03:57 PM
TAF Motorsports's Avatar
With the AC blowing listening to tunes.....
Old Dec 9, 2004 | 04:06 PM
next's Avatar
Here's what I found...
0 -> 60 in 3.8 sec.
Top Speed 200 MPH
2,900 #'s
5.7 #'s/HP
Chassis & Suspension development by Pratt & Miller,
Aluminum Hydroformed frame produced by DANA
- 345/30x19 Rears
- 6 piston Front, 4 piston Rear Brake Calipers
- Cross Drilled (cast and camfered) Rotors (possibly Brembo)
Engine Development by KaTech
To be hand built by new HP Engine Plant
LS7 427ci/ 7.0L. 500HP/500 Ft Lbs (512 HP derated to 500HP)
- 2 OHV (3 OHV not necessary for target HP)
- Raced based CNC ported Aluminum Head with 70cc chambers
- 11.0:1 CR
- 46 mm (1.81") Titanium Intake valve
- 41 mm (1.61") Na filled Exhaust Valve
- 104.8 mm Bore (4.125") , 101.6 mm Stroke (4.0") Aluminum block
- Forgrd Crank
- Forged 6 bolt main Bearing Caps
- Titanium Rods
- Cast Aluminum Flat Top Pistons
- 0.591" Lift Cam (15 mm)
- Dry Sump
- 90 mm Throttle Body on Composite manifold
- Ram Air
Old Dec 9, 2004 | 04:10 PM
Turo's Avatar
holy crap, that is my next car!!!! i just have to wait a few years till i can afford it
Old Dec 9, 2004 | 04:19 PM
InsomZ's Avatar
wow is all i can say.. that will be at supercar level w/ z06 weight & that power.
some 427's are putting down 500rwhp.. do you think GM is under rating these? seeing the 11.1:1 compression ratio i'd think it would put down good #'s
a 10sec bone stock car would be well worth the $$!
Old Dec 9, 2004 | 04:20 PM
slo-vette's Avatar
That is crazy.
Old Dec 9, 2004 | 05:05 PM
Ralphy g-Machine's Avatar
x12. Bitchin' car.
Old Dec 9, 2004 | 05:12 PM
TriShield's Avatar
Duct to cool the rear brakes. Are they supposed to be huge, obnoxious, and stick way out from the side of the car?
Old Dec 9, 2004 | 05:17 PM
black_z's Avatar
Bad ****** ***. That thing is really gonna scoot with a tire.
Old Dec 9, 2004 | 05:26 PM
WhiteDiamond's Avatar
Anybody catch the intake valve size?? 500 hp with that tiny, itty bitty valve...??? Guess what a big cam, big valves and some headers will do!! 540rwhp!!
Todd
Old Dec 9, 2004 | 07:06 PM
Jammer's Avatar
Can anyone see if that intake is LS2 style or drastically different?
Old Dec 9, 2004 | 07:19 PM
Bink's Avatar
Hey Insomniak! I have a 2001 SW Z06 just like yours!!! Pretty car!
Old Dec 9, 2004 | 07:22 PM
-Q-'s Avatar
-Q-
My god
Old Dec 9, 2004 | 08:02 PM
stik6shift93's Avatar
It looks to be different, the runners are more squared off as opposed to the curved runners on the ls1/2/6 intakes. Maybe it's because they are using a c5r type casting, which if i remember correctly carrys a square intake port as opposed to the catherdral shaped port on the ls1/6 heads.
Old Dec 9, 2004 | 08:06 PM
Jake99SS's Avatar
Todd
Caught that too. I wonder if that's the valve size for the 3-valve config...
