GM provided Z06 and LS7 specs inside
Old Jan 9, 2005 | 06:53 PM
  #81
DRACO911's Avatar
I need a job selling drugs or something . Since I can't sing worth a damn.
Old Jan 9, 2005 | 07:08 PM
  #82
70 TA's Avatar
Originally Posted by J-Rod
According to someone from Chris @ AP Engineering (who used to work for Katech). The heads flow 370... So, my guess is with port work, they'll be closer to 400...
Well that would be awesome and if thats the case then this is 500 RWHP and not 500 Crank HP
So all we need is a cam swap and headers?
Old Jan 9, 2005 | 09:49 PM
  #83
INVISIBLEZ's Avatar
I want a set of LS7 heads!!!!!
Old Jan 9, 2005 | 10:39 PM
  #84
BigTex's Avatar
So the LS7 has a new block, crank, and heads. Is the bore spacing the same as an LS1/LS2? Its great that GM is now going to have a factor big bore block, high flow heads and 4" crank. But are these parts directly compatible with the other motors?
With the "hand made" touch these motors are getting, I'm scared of the crate motor pricetag.
Old Jan 10, 2005 | 01:15 AM
  #85
BurnOut's Avatar
I have been told by someone with some inside connections to expect 475-ish to the wheels (stock). On one hand, that seems pretty optimistic, but on the other hand, we ARE talking about an 11:1 427 with some pretty friggin' beefy heads and a pretty good sized (lift-wise, anyhow) cam. I'd be willing to bet that the intake side of the cam is somewhere in the 225-230 area @ .050, but I think it'll have a pretty good lobe sep (like, 115+) for idle quality/emissions; all of that is pure speculation, BTW.
Old Jan 10, 2005 | 03:53 AM
  #86
z-ya's Avatar
There goes the ducati
Old Jan 10, 2005 | 01:19 PM
  #87
70 TA's Avatar
Dude you were right. LS7 heads flow 43% more than LS6 heads so in the 370 range. Thats unreal
Old Jan 10, 2005 | 02:02 PM
  #88
Bink's Avatar
Probably the 2002 - 2004 Z06 cam with 1.8 rockers.
Old Jan 10, 2005 | 04:11 PM
  #89
WS-Sick's Avatar
All of this makes me think back to when I saw an episode of "My Classic Car" (I think that's the title) on Speedvision that showed the prototype TigerShark. I guess all of this has been in the works for a long time. Anyone think GM can surprise us again?
Old Jan 10, 2005 | 07:12 PM
  #90
RobLS1's Avatar
thats bad ***
Old Jan 10, 2005 | 08:34 PM
  #91
NOSjohn's Avatar
Restricted User
They also have this on their web site now...if nobody else noticed...not sure.
Here:
http://www.chevrolet.com/corvettez06/
The Z06 badge is THE BEST !
Someone said I was stupid or foolish for thinking the engine was going to be dry sump...now what grasshoppa' ?
Old Jan 11, 2005 | 05:47 AM
  #92
flynbludream's Avatar
I can't believe no one has commented on the fact that it has forged pistons.
Old Jan 11, 2005 | 07:52 AM
  #93
Fulton 1's Avatar
This is a point of great debate right now since the GM literature contradicts itself. Previous indications were that the pistons will be cast, not forged. Forged pistons were supposedly dropped due to concerns over cold start noise (after the LS1 cold start fiasco). I hope they are forged, but I think the references we see to that are erroneous.
Old Jan 14, 2005 | 10:17 AM
  #94
CamaroCain's Avatar
well i wnat to know when of these monster units will be sold as crate engines and how much you guys recon they will cost?
One of the GM performance parts places online showed the LS7 (crate motor) listed as being available in the fall. No price shown yet of course. I would guess around $10k
Lynda
Old Jan 14, 2005 | 01:18 PM
  #95
John B's Avatar
Moderator
The crank is set up for driving the dry sump pumps so unless you go this route with the same front cover and camshaft set-up I don't think that the 4" crank is directly interchangeable.
Old Jan 14, 2005 | 03:49 PM
  #96
AgentOrange's Avatar
anyone have the pistons part numbers available?? Maybe I can solve the debate??
Old Jan 14, 2005 | 06:15 PM
  #97
2MuchRiceMakesMeSick's Avatar
Originally Posted by T-maxx
I like those specs..but... won't it suck when a fox body stang keeps beating you light to light I still want one!
What are you saying
Old Jan 14, 2005 | 09:38 PM
  #98
someday's Avatar
no one saw that it has 56mm (2.20") intake valves? even the biggest aftermarket valve is only a 2.08"... 2.20" is damn huge... as for cam size, i'd guess a 218/230 on a 116... we know the lift is .591 with 1.8 rockers...
Old Jan 15, 2005 | 10:59 PM
  #99
hamburgler25's Avatar
Default hmmmm 7.0litre
so who is gonna be the first guy(or gal) to put one of these crate motors in there half ton pick-em-up truck,,,hmmmm maybe me
Old Feb 27, 2009 | 05:10 AM
  #100
lsxballs's Avatar
Default Will ls7 cam fit an ls1 motor?
Like the title says
