4.125 Bore
I know the C5R is generally used to do this, but is the LS7 block going to be cheaper? I've heard it comes 4.125 bore stock.
And doesn't the 2.2" valve LS7 head, with heavily raised, square intake ports, offset pushrods, and matching 90mm intake manifold redefine what a big displacement head should be?
Thanks,
David
Thanks,
David
It is just pushing it. However the idea of an aluminum 457 cid small block is very appealing.
The LS7 heads do seem interesting. Does anyone have flow numbers on them yet? For some reason it seems to me that this engine should be making more hp...I suspect the exhaust system is an issue.
Heads probably need SOME porting, but with a 2.2" intake valve, the ports are probably
big enough to flow as good or better than the BEST LS6 heads. And with porting
probably as good as C5R ( 400CFM ish ).
I have 5 machined sitting on the floor...Rob we're similarly priced ($3300) Have you had any running yet?
