LS2 Large Bore Blocks and Engines Available - Re-post
Originally Posted by 11 Bravo
Out of curiousity, and I know it has not been tested, but how much boost/spray could these block possibly handle?
LS1TECH Sponsor
We are rating them at 1000HP. How you get there is up to you
If you are looking at that much power, I would be more concerned with the rotating. Make sure you use billet main caps and good quality internals.
No knock sensors as in LS1/6 locations. I modify the blocks to accept the LS1/6 sensors on the sides of the blocks but I have not completely tested that location yet. I'll be finished with that this week. Just mounting them in the spare motor mount holes will not work with some header systems.
Originally Posted by 2001 Pewter WS6
Why no warranty? You would at least hope for 90 day or something...
You wouldnt believe the number of people who go out after buying a brand new motor, strap on nitrous and run it with NO CLUE on how to tune.
Motor spins a bearing, throws a rod, lifts a head or drops a ringland from detonation. Person calls vendor and says "I never ran nitrous, your motor is junk"
Someone decides to swap injectors, the tuner makes a mistake and washes down the cylinders.
Someone misshifts at 6800rpm motor sees 9800rpm and throws a rod.
Engines fault? NOPE!
Owners fault? YEP!
Originally Posted by DavidNJ
I'm missing something...why no knock sensors?
And what intake would you use?
LS2 blocks have the knock sensors on the side of the block instead of the lifter valley on the Gen-III's.
Has anybody tried adapting the Gen-III sensors to fit on the side mounts of an LS2? You'd have to re-cal the knock sensor, but it might work...
LS1TECH Sponsor
Post #62
Originally Posted by mikey
