Will the C6 LS2 oil pan fit the F body
As the title states, has anyone checked if the C6 oil pan will fit the F body?
I hope to be pulling above average G's with my new 415 LS2 block and suspension in place and Kuhmo V710's. It seems to be significantly different than the C5 and has very good baffle arrangements for high G loads.
When my motor is out next month, would be a good time to change if it fits.
Thanks in Advance,
Rampant
![](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_confused.gif)
Thanks in Advance,
Rampant
![](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
It's going to be close, the ls-2 pan isn't as deep as the ls-1 f body but the sump extends further to the front it could hit the cross member. the ctsv pan would fit for sure and is capable of sustaining oil pressure at 1 g
