LS2 Knock Sensor Issue
Ok, I have searched and read and still don't have a clear answer for the use of an LS2 stroker in 1998-2002 F-bodies. I'd really like to get one of the new LS2 stroker short blocks from one of the reputable vendors, but the knock sensor issue still doesn't sound like it's been solved IN THE REAL WORLD (not on a dyno).
Has anybody built an LS2 stroker, used the LS1 knock sensors in the side of the block and installed in their F-body? What has the results been? What do you need to worry about? Lastly, can you use Kooks, QTP, or Hooker headers with this combination??
Thank you.
Thank you.
LS1Tech Sponsor
You can almost put them anywhere in the block,then you will have to test them.Now,how would you know if it's right?Well probly within time it will eat the pistons if they are wrong or you can hear KR and adjust by that.I personally see no reason for KR sensor's in my own vehicles and even have them disconnected in my stock,blown motor.KR sensor's are for getting bad gas(which you can feel/hear anyway's) or for someone that can't tune the car.
So, by tuning the PCM "properly" knock should not be an issue? I always thought that the knock sensors allowed the PCM to run timing right to the edge before detonation. By eliminating the knock sensors in the computer, aren't you leaving horsepower on the table? Or, if too much timing is dialed in, can't detonation occur on hot days or bad gas days?
Sorry if these are dumb questions.
I turn them off on most of the cars that I have tuned. There is more power running a few degrees before you will even see knock in the fist place. KS are a band aid for bad tuning. Just don't put a larger cam in and a set of better heads and plan to tune it in a few weeks. As long as your tune is on you won't have a problem.
My LS1 KSers were put in the passenger side (both) since they cleared easily on that side and wouldn't on the drivers side. The harness was also ez to connect there.
My first and only log so far was when I drove it home and only lasted for about 3 minutes before my logging software cratered and I had to switch to AutoXRay for the remainder of the trip.
That 3 minutes did have several episodes of mysterious electrical malady that did cause the pcm to hiccup. The KSers did sense that knock and retarded timing.
I am starting a thread on "tuning the 402 (8) from a H/C car" in the tuning forum. Follow that if you like and I will keep posting my tuning challenges and successes over the next several days and weeks.
Perry
Perry
Perry
Perry
Got my part throttle pretty close from the get-go. Got the idle and idle follower pretty close tonite. Did some driving.
the LS1 knock sensors seem to work perfectly in the block. I am picking up inaudible as well as very minor (0.4 deg retard) knock right where I would have expected it from my experience with my H/C LS1.
So that bogey seems to have been put to bed....at least as far as I can see.
Perry
Perry
Originally Posted by The Dragon
Ford's don't run them. ALL cars didn't run them for yeeeeeeeeeeeeears. Good tune . . . no worries.
![](http://www.sccow.com/joshs/huh.gif)
9 Second Club/LS1TECH Sponsor
That's pretty much how we have been doing the LS2/LS1 hybrid harnesses. I make the knock harness so that it will reach wherever you can comfortably mount the sensors (both on one side, one on each side, back of the heads, etc.).
![](http://img.villagephotos.com/p/2004-6/746244/LS2LS6_hybridharness07_ESC.jpg)
Perry
Perry
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic1124_1.gif)
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
www.speartech.com
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Originally Posted by rookiels1
hmmm all 3 thunderbirds I owned had knock sensors in em... ![](http://www.sccow.com/joshs/huh.gif)
Originally Posted by DrkPhx
Perry - Is the knock you're picking up at WOT or normal conditions?
I saw it once when I hit the throttle hard and once when I tickled it at low rpm low load conditions. So the latter proves to me that it is as sensitive as it was before.
PK
Dam#. That is weird. Why would they do that and not put them on their Mustangs?? I personally would feel safer with them and I tune these cars. Great tune or not . . . with some exhausts (like mine) . . . it would be dam# difficult to hear knock over the noise.
My sensors seem to be operating normally as I get more miles on the car.
It is not quite as sensitive to low load mid rpm knock (say slightly above idle and less than 2600 rpm and a relatively rapid acceleration that would send my sensors in the LS1 into a frenzy). But it will definitely see knock and retard the timing when it sees it.
I am gonna guess that the sensors are a bit less sensitive in the block but frankly that is a good thing.
Perry
Perry
Perry
Perry
