LS7: The Gloves are Off
Old Apr 15, 2005 | 05:07 AM
bigeller's Avatar
Default LS7: The Gloves are Off
Article from Super Chevy Magazine........
A racecar for the street.
That's the simple description of the '06 Corvette Z06. And since every racecar needs a racing engine, that pretty much sums up the Z06's new LS7 powerplant, too.
The next evolution in the Gen IV engine's development, the 7-liter LS7 is technical marvel and not-too-far-removed associate of Chevy's LeMans--winning Corvette C5R racing effort.
Frankly it also is a surprise--a surprise that at any mainstream manufacturer outside, say, Maranello, Italy, or Stuttgart, Germany, would produce such a specialized beast as a production engine.
The raw numbers are mighty impressive: 500 horsepower and 475 lb-ft of torque from the 7-liter version of the Gen IV. Chevy says 7 liters translates to 427 cubic inches--a magical number to Chevy fans. Actually, we think it's a cube or two more than 427, but why quibble?
The basic specs are just the meringue on the pie. Beneath lies a roster of performance parts that seemingly belongs on the order sheet of the Pratt and Miller racing team:
  • Unique block casting with 4.125-inch bores
  • Forged steel crankshaft with 4-inch stroke
  • Titanium connecting rods
  • 11:1 compression ratio
  • Camshaft with 0.591-inch lift
  • CNC-ported aluminum cylinder heads with siamesed valve seats
  • Titanium intake valves (56 mm) and sodium-filled exhaust valves (41 mm)
  • Dry-sump oiling system with firewall-mounted oil reservoir
The LS7 is hand-assembled at a new specialty engine build center operated by GM in Wixom, Michigan. The facility builds maybe 30 engines a day, each assembled by a single builder who picks up the bare block and follows through until he or she signs off on the complete engine.
Like the engine itself, the specialized assembly procedure of the LS7 is remarkable for a regular production engine--especially within the mass-production realm of GM. With world-dominating performance and a hand-built pedigree, the LS7 jumps to the top of the "best of" small-block list before the first Z06 hits the street..
http://www.superchevy-web.com/techni...ls7/index.html
Old Apr 15, 2005 | 04:31 PM
72chevy2's Avatar
cast aluminum pistons and titanium rods? good n/a motor, boost may be tricky! lil nitrous never hurt anyone though... we shall see
Old Apr 15, 2005 | 08:56 PM
SDB's Avatar
SDB
I hope they change to forged pistons...then it just needs a big cam and a 250 shot...
Old Apr 15, 2005 | 08:58 PM
ss rally red's Avatar
I hope to be able to afford to be able to install one of these in my very low milage 02 SS(Well I will make it happen). I think it would be a great mix of history and factory muscle.
Old Apr 16, 2005 | 01:30 AM
sm2C5's Avatar
Unhappy
You would think A magazine called "Super Chevy" could get the cam specs
for the LS6 right (see table). Makes it hard to take them seriously.
Old Apr 16, 2005 | 12:42 PM
mikemodano9c's Avatar
it says .591 lift in the body, but .593 in the graph on the bottom?
Old Apr 16, 2005 | 11:28 PM
bigeller's Avatar
Don't know what's up with that.
Old Apr 16, 2005 | 11:41 PM
Wnts2Go10O's Avatar
typos much?
 Michael S. Palmer
Old Apr 16, 2005 | 11:45 PM
bigeller's Avatar
Yup, they must have.. Picture taken right from the site..
Old Apr 17, 2005 | 12:11 AM
BlueSix's Avatar
They also got the '01 and '02 LS6 cams mixed up.
Old Apr 17, 2005 | 12:22 AM
cyphur's Avatar
https://ls1tech.com/forums/generation-iv-internal-engine/257902-gm-provided-z06-ls7-specs-inside.html
they supposedly ARE using forged pistons. GM either changed their minds or this magazine is FUBAR.
Old Apr 17, 2005 | 11:02 AM
John B's Avatar
Moderator
Sorry, this is just untrue. To set the record straight on this I wrote an e-mail directly to GM and received this response below. Hopefully this puts this issue to rest once and for all!
John:
The pistons are cast aluminum - both in the production version and in the crate engine. I've attached the specs for the production and the info about the crate, and as you'll note, nothing changes. No plans to change in the future.
(See attached file: 4_LS7 Specifications.rtf)(See attached file: 0_GMPP LS7 Crate.rtf)
You're right, there does seem to be some confusion in the media about a few things. Just last week a media source said the Cadillac STS would carry the LS7, which is inaccurate. It will carry the LS2 - Supercharged.
Thanks for checking in and getting your facts straight.
Cheryl McCarron
Assistant Manager, Communications
GM Service and Parts Operations
tel: 810-606-3112 cell: 248-330-2801
mail: cheryl.mccarron@gm.com
P.S. The attachments that she sent me are word documents with the LS7 spec's that are already posted on this board elsewhere in several places and GM's webpages so I'm not going to take up more bandwidth and repost them here.
Hope this helps!
Old Apr 17, 2005 | 11:20 AM
cyphur's Avatar
John B., good deal. I was going off the press release J-Rod posted up. Always like having the right info. Just wonderin why GM puts out two different sides of the same fact about the same motor??
Old Apr 17, 2005 | 01:55 PM
SS00Blue's Avatar
Ms. McCarron also states that the STS-V will "the carry the LS2 - Supercharged" and that's just not true, so how can the statement about the pistons in the LS7 be credible?
SC-
Old Apr 17, 2005 | 08:23 PM
branden7's Avatar
how much do you think the LS7 crates will go for? just out of curiosity. How much work will they be to put into 4th gen f-bodies?
Old Apr 17, 2005 | 10:37 PM
ChucksZ06's Avatar
Car and Driver indicates caddie will be ls2 supercharged also. GM has to warranty engine for lots of miles and cannot have endless recalls from stupid people who bitch about piston noise...there are thousands of people who make them tear down perfectly good engines cause they rattle a little when cold. I think that is why they are not using forged pistons.
Old Apr 17, 2005 | 10:47 PM
WS6 #3392's Avatar
This is a question that I have as well. What do you guys think the crate LS7 will cost?
Old Apr 18, 2005 | 12:19 AM
cyphur's Avatar
here's quite a few guesses.
