GM 3 valve cylinder design
http://turbobuicks.com/forums/showth...t=page=1&pp=15
You will have to read a wya into it where I said that GM was making the same or damn near same power as Ford was but GM using 2 valves per cyl and ford 4 and GM N/A vs Ford S/C. Well a guy came back adn said GM LS2 and LS7 are 3 valve, since I had sold my 01 Z last year I got out of the LSx scene for awhile and now that I have another LS1 Z I got back in and was not sure if GM went on with the LS2 LS7 3 valve design
http://turbobuicks.com/forums/showth...4&page=1&pp=15
GM pays us to do the machine work...how does that suck? I never really read the other threads about the 3 valve heads, but you seem to have all the first hand info on them? Am i right on this guess or do you just have something against them? Not looking for an argurment here just want to compare your info with what we hear from the guys testing and developing them.
GM pays us to do the machine work...how does that suck? I never really read the other threads about the 3 valve heads, but you seem to have all the first hand info on them? Am i right on this guess or do you just have something against them? Not looking for an argurment here just want to compare your info with what we hear from the guys testing and developing them.For instance take fords dohc v8's, though they make a very little bit more hp per liter, go and compare power per pound of motor. You will find out that gms old pushrod technology is much more efficient than the current ohc technology ford is using. Also not only does an ohc motor add more weight in the front of a car that already has a heavy front weight bias, it also adds the weight to the top of the motor which increases the center of gravity which also hurts handeling. Also if gm used ohc's in their motors you'd have less sleek cars with much more bulky front ends, take the corvette for instance. If gm decided to use an ohc type v8 in the vette they'd have to raise the hood line a few inches, car would look like garbage imo if that were to happen.
pman,
Have you seen any indication that there are versions of these heads
which have provisions for side- or central direct-injection?? Do you have
any idea of the valve sizes (diameters)?? What bore sizes are these heads
designed for?? Has anyone given you any hints as to the flow rates of these
heads? Is the first application of these heads to truck or cars? I assume V8's
will appear before the V6's and V10's. Do intake manifolds for these heads
look anything like either the LS2 or LS7 intake manifolds? Are the heads much
heavier than 2V heads. What is the valve angle on these heads? Are there many
different versions of the heads??
Any thoughts would be appreciated. Don't get yourself fired!
Lack of variable valve tech is for sure, but lack of power for the price? Good question. I would like to know how that 3v design will work myself, because the exhaust valve arrangement looks a bit awkward. I couldn't see why it couldn't work, just looks like a proprietary design that might need much r&d before it can work better than GM's 2v OHV design. If my memory doesn't fail me, I believe that there was a company called dominion that had a retrofit design for a 4v OHV. don't remember what ever happened with it.
