Can i use ls7 cam in the ls1?
Old May 20, 2005 | 04:46 PM
oOoLy's Avatar
Default Can i use ls7 cam in the ls1?
Old May 20, 2005 | 07:28 PM
Blue Hawk's Avatar
Only God and the General knows... for now!
Old May 20, 2005 | 11:41 PM
gto69judge's Avatar
Default Yes
The LS7 cam is the same design (with different lift and duration) as the LS2 cam. If you use the LS2 front timing cover, cam gear, and cam position sensor, you can use any LS1,LS2,LS6, or LS7 cam.
Old May 22, 2005 | 03:49 PM
oOoLy's Avatar
Thanks for your help .... so i must change the front timing cover, cam gear and position sensor to put the LS7 cam.
Old May 24, 2005 | 05:09 PM
oOoLy's Avatar
from where can i get the front timing cover, cam gear and position sensor to put the LS7 cam?
Old May 24, 2005 | 06:12 PM
Z06PSI's Avatar
Sdpc......
Old May 25, 2005 | 12:30 PM
oOoLy's Avatar
Thanks redrumss ....
Old May 25, 2005 | 12:42 PM
Patrick G's Avatar
LS1 Tech Administrator
You will not want to use this cam in a 346. It will be a dog. The intake closing point is 49 degrees ABDC which means it will peak around 6500 rpm in a 346 and be a turd at low rpm. This cam was designed specifically for the 427. For a 346, you want an intake closing point closer to 44 degrees ABDC (at .050").
BTW, cam specs are 211/230 120LSA, 123 ICL.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
