Just made my own Kill Switch
Well I was having problems with the clutch switch today
so I took the wiring down for it and decided to make a kill switch. I figured hell if the clutch won't go in they can override that vats maybe but if the clutch isn't tripping the switch GL. So I went to radio shack and grabbed a simple 2 wire in 2 wire out switch i mounted the switch right inside the center console right where the opening is at. Kinda hard to explain will get some pics up later. I ran the 2 wires from the clutch switch into the new switch then ran the 2 wires from the switch to the wiring cluster.
And now whenever I am in a bad part of town and i have to leave the car somewhere. I just keep the car in neutral lock the car and forget about it. It could still be stolen but hey every little bit helps. I also can flip my fuel cutoff switch down under the drivers seat if I really feel like it will get stolen. All i have to say is for 30 minutes of time it makes me feel much better about leaving my car somewhere.
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
