My LS2 dyno, questions!
I saw that it was a dynojet
It's pretty typical for a dynojet to show wildly different numbers between pulls. This is where the 3 pull came from. When I have a bone stock car on my Mustang dyno I never see more than a 3-7hp difference between pulls when no changes are made. When you have a loading dyno you can get much more reliable and accurate numbers. As far as being that different I bet if you look at the logs, you'll notice that the first two peak numbers are probably at lower RPM's than the latter ones. (didn't turn the car as hard)This is the only thing that I can think of that would make the numbers as much as 50hp off.
Highly recommended part if drag racing is important!
Best,
My first pull was 305rwhp/301rwtq. My second pull was 297rwhp/394rwtq. These pulls were back to back. I know the engine temp was the skinny bar past the fat middle bar. Since the GTO doesn't show actual engine temp Im not sure what it was.
... My third pull was 351rwhp/349rwtq and my fouth pull, agian back to back, was 353rwhp/351rwtq.
It takes off like a bat out of hell with only a chirp of the tires. For some reason I have never been able to light up the tires off the line, it just hooks up and goes.
...Then again, that could just be me. I've been driving so many FWD cars that love to spin off the line that I subconsciously am afraid to floor it and detonate the transaxle.
I'm also interested in finding out about torque management and LS2edit when it appears.
There is BOTH engine TM AND Trans TM.
You are talking about trans upshift torque reduction which is a table unto itself.
I'm suprised Dynojet has not sued them over some of the crap they spread. The truth is that while they have some limitations, a Dynojet will repeat as close as any, actually closer than most Mustangs. 7 rwhp variation on an untouched vehicle, at the same temps, is unheard of here. We seldom see more than a couple hp, if that, if the temps are all equal. Probably the best one out right now is the Superflow. That is what I would have bought if they had been building chassis dynos when I bought mine. I always liked their engine dynos. I looked at the Mustang, but too many of the shops I tune for, that had Mustangs, were having some reliability/maintenence problems at that time. About seven years ago. They are probably better now.
People that are now actually tuning the LS2s know that coolant and intake air temps make much more difference in spark advance than the LS1/LS6 PCM. They pull a butt load of spark advance as the temps go up. That is easily addressed when tuning them. If that gentelman was driving his GTO on a warm day, in traffic, with the AC on, and did not cool it off first, he could easily gain that much power between pulls by simply letting it sit for a while with the hood open, and maybe a fan blowing on it. The LS2 in factory tune, is very sensitive to coolant & intake air temps. Even much more so than the old iron block LT1/LT4. Get an LS2 near warm enough for the fans to come on, and power drops like a rock.
Good luck, Ed
Good luck, Ed
Hey johnny you should just come race either one of my cars and see how your gto does. My 04 only has ten mor horses than your car so it would be a good race.
Good luck, Ed
My stomach sank to about my knees because I was so disappointed that LS1 GTOs were dynoing higher than my LS2 GTO. I then let the car sit and cool for 30-45 minutes and also disconnected the battery. I reconnected the battery and fired the car up and made two more pulls. My third pull was 351rwhp/349rwtq and my fouth pull, agian back to back, was 353rwhp/351rwtq.
saved. I can call and ask. Thanks a lot!
How else does one explain the wopping 394 rwtq on the second pull? Then the loss of 50 rwtq on the 3rd and 4th pulls, while simultaneously gaining 50 rwhp.
(unless you meant to report 294 rwtq for the secon pull)
Maybe you should take the GTO to a diff. dyno.
