scotch brite engine bearings????
Old Jul 11, 2005 | 06:53 PM
tomulrich's Avatar
Default scotch brite engine bearings????
I have read...never to use scotch brite on engine bearings because it embeds aluminum oxide in the bearing which can eventually wear on the crank.
I have a local engine builder who builds C5R engines for 24hr race purposes....he lightly scotch brites his bearings.
I did this to my main bearings(just enough to shine the bearing surface)......I am still building the motor...and am wondering if I should remove the caps and change the bearings before going any further?
How many of you use scotch brite or know of engine builders who do...???.
I have searched and read everything.....cant find anything that says...there is a benefit from doing this...
let me know what you guys think.
Old Jul 11, 2005 | 08:23 PM
Brains's Avatar
sandpaper would likely get some grit in there, scotch brite shouldn't (its not a granular abrasive).
Old Jul 12, 2005 | 10:54 AM
ChucksZ06's Avatar
I sure would not do it unless there is an obvious flaw on bearing surface...maybe he wants to take off the soft surface coating on the bearings.
Old Jul 12, 2005 | 11:16 AM
427's Avatar
427
I have been doing this for about 20 years. Some bearing guys at Federal Mogul give me a hard time about it, but I like to clean them with mineral spirits and scotch brite before assembly.
Kurt
Old Jul 12, 2005 | 01:56 PM
hellbents10's Avatar
LS1Tech Sponsor
But, what does Kurt know...lol.
Old Jul 12, 2005 | 02:50 PM
SLED28's Avatar
I use scotch brite also when they have a high spot or something and then brake clean it very good.
