412ci Ls2
Old Jul 28, 2005 | 12:05 PM
Dbluegoat's Avatar
Default 412ci Ls2
Anyone have this?
I currently have a 04 GTO with the LS1 and I am thinking about going to this......
any thoughts or concerns? Is Rapid Motor good?
http://www.rapidmotorsports.com/mode...=4&intYearId=9
Part No: RM-LS2412CR
Price: $11,995.00
# New GM 6.0L LS2 Aluminum Block
# Callies Racemaster Forged Crankshaft - 4.100"
# Callies Connecting Rods
# Diamond Pistons with -2cc or -15cc valve reliefs
# Childs and Albert Ring Set Plasma Moly
# Clevite H Series Race Bearings
# ARP 2000 Rod Bolts
# ARP Main Studs
# Rotating Assembly Fully Balanced
# Engine Blueprinted
# Rapid "Dominator" series Custom Hydraulic Roller Camshaft
# GM Timing Set (required)
# GM LS2 Timing Chain Cover
# GM LS2 Lifter Valley Cover
# GM LS2 Cam Position Sensor
# Airflow Research 225 Cylinder Heads
# Resurface Heads to Desired Compression
# ARP Head Studs
# Cometic MLS Head Gasket Set
# Custom Length Moly Pushrods
# Crane Quick Lift 1.7 Stud Mounted Roller Rockers
# Comp Cams 850-16 Hydraulic Roller Lifters
# Fully Assembled Crate Motor
# No Engine Core Required
# Does not include intake manifold, windage tray, oil pan or rear cover
# Upgrade to Morel Lifters add +$300
Old Jul 28, 2005 | 12:38 PM
slow trap's Avatar
that should be a good combo. the 4.1 inch stroke "should" produce great low end.
Old Jul 28, 2005 | 12:42 PM
RAMPANT's Avatar
Originally Posted by Dbluegoat
Anyone have this?
Price: $11,995.00
# ARP Main Studs
# ARP Head Studs
I have one going in the my car next week.
I will post the numbers as soon as I have them
I have a slightly different list of parts, but an Eagle 4.100 crank and it balanced up really nice only slugs needed.
The motor is pretty much done I'm just waiting on my freshened up M6.
Rampant
Dbluegoat's Avatar
what would be the benefit of upgrading to the morel lifters they mention?
Old Jul 28, 2005 | 12:43 PM
Dbluegoat's Avatar
Rampant
sweet cant wait to see the results......arer you gonna have the knock sensors?
Old Jul 28, 2005 | 01:09 PM
RAMPANT's Avatar
They lock up like a solid lifter above 4000rpm adding stability to the valve train. So I hear anyway. Supposed to a few hp up top.
Yes, they will be on the side of the block, but we will have to check for the clearance around my QTP's first.
I'm hoping for the north side of 500rwhp and maybe the torque too!
I'll PM a link to some photo's as the builder is not currently a sponser. hopefully soon though.
Rampant
Old Jul 28, 2005 | 07:44 PM
SLED28's Avatar
Here's some pics of Rampants motor
http://www.gmperf.com/page33.html
Old Jul 28, 2005 | 08:15 PM
1FST99Z's Avatar
sweet I myself have been looking at that setup as well. should put you right in the range of 500rwhp +
Old Jul 28, 2005 | 08:25 PM
RAMPANT's Avatar
I hope you are right and maybe just a little low!
Old Jul 28, 2005 | 08:58 PM
Dbluegoat's Avatar
what kind of torque do you expect?
Old Jul 29, 2005 | 09:12 AM
Builder's Avatar
Good stuff!
Old Jul 29, 2005 | 02:25 PM
ezss's Avatar
rapid is good -- you should have no problem making over 500rwhp. I have a fairly tame 393 and am making over 500, his 402 LS2 makes 525-555 with those heads.
Old Jul 29, 2005 | 10:25 PM
DavidNJ's Avatar
I'm sure it is a good package. However, for over $10k plus installation and brick and brack I would go to a big bore, which unshrouds the valves and gives a further boost to displacement. Up to 4.2" bore can make a 457 (or a 454 or 455).
455 GTO...umm sounds familiar.
Old Jul 31, 2005 | 12:22 AM
Caveman's Avatar
10 & 11 Second Club
That motor could make a pretty fast GTO.
Old Jul 31, 2005 | 09:21 AM
52172's Avatar
you can get a 402 with the afr 225 right now from texas speed without any core charges for only 6600 don't spend 11000 whatever you do plus installation there are much better prices out there. SDPC has similar prices. 6600 includes a cam installed also. Only main difference is a eagle crank instead of a callies and you could also get the 4.10 eagle crank so for 6600 you can get 412 CI.
Old Jul 31, 2005 | 10:27 AM
Caveman's Avatar
10 & 11 Second Club
The callies crank is much better then the eagle but the difference in price from the engine builders is huge.
Old Jul 31, 2005 | 01:10 PM
Pavetim's Avatar
What would you think of that combo with a whipple charger on top? I want somethign that is gonnna kick butt but gonna last too. It will be going in my 2002 trans am. Think the aluminum block will be enough for this combo or should you go with the iron block?
Old Aug 9, 2005 | 07:47 PM
turborail's Avatar
An Eagle crank sure isn't a weak link in that engine. The aluminum block is the weakest link. I would run that eagle crank in a 1000 hp turbo motor but I wouldn't run the block at that power. An Iron 6.0l block is cheaper holds a lot more power and weighs about 65 lbs more.
Old Aug 13, 2005 | 08:16 AM
SLED28's Avatar
Default Block Strength
The LS2 block will take 1000HP. I have run 4.100 BigBore LS1 blocks to close to 170mph in the 1/4 and it held up for numerous passes and seasons. Of course it had lots of strength options also ( oversized ARP studs, welding,etc).
The LS2 block has nearly a 1/4" of added aluminum around the sleeves, and also siamesed tying them in all together making it very rigid!
