Cable Throttle Body
Old Aug 7, 2005 | 08:27 PM
SSmonte's Avatar
Default Cable Throttle Body
Plans are to swap a new LS2 into my 88 Monte Carlo and I am keeping the throttle cable...not drive by wire. What throttle body options do I have to bolt to the LS2 intake to make the throttle cable driven again? I know the TB on the LS2 has 4 bolts and is 90mm but I really dont know my options.
Thanks
Nick
'88 SS
Old Aug 8, 2005 | 12:23 AM
77ZETA's Avatar
Thanks
Nick
'88 SS
The fast 90mm tb. fits perfectly in there.
We tried this on my LS2!
I don't know whats needed to make it work though.
Old Aug 8, 2005 | 05:43 AM
Holden LS1 Tonner's Avatar
http://www.sdpc2000.com/catalog/2777...ottle-Body.htm
KJ@SDPC (a forum Sponsor) may be able to help you
Old Aug 8, 2005 | 06:30 AM
SSmonte's Avatar
I had emailed SDPC last week but haven't heard a response...also PM'd KJ so maybe he will get back to me soon.
Thanks
Nick
Old Sep 15, 2005 | 09:07 AM
jellison's Avatar
I think this http://www.sdpc2000.com/catalog/2777...ottle-Body.htm is what I want.
Want an LS2 crate engine to go in a non LS2 car to run a cable throttle - this replaces the one on the LS2 (I hope I do not sound to dumb here!!)
Old Sep 15, 2005 | 10:37 AM
technical's Avatar
I haven't had a good look at the electric TB's, but maybe you could retrofit a cable shaft into the TB for a lot less $$$.
Old Sep 15, 2005 | 02:00 PM
JarrettL's Avatar
As 77ZETA said, the FAST throttle body works as well as the Nick Williams 90mm model. From what I heard from Nick, the throttle body bolts up without using the top bolt. It still lines up perfectly though.
Old Sep 15, 2005 | 02:06 PM
Nick Williams's Avatar
This is correct
Old Sep 15, 2005 | 06:46 PM
77ZETA's Avatar
I was told all you have to do is delete the drive by wire from the ecu.This came from two diferent tuner guys.
Old Sep 15, 2005 | 10:01 PM
LS2Monte's Avatar
The drive by wire will be deleted from the PCM...anyone have a link to the fast 90mm TB or nick williams TB?
Thanks
Nick
Old Sep 15, 2005 | 10:03 PM
SUX2BU's Avatar
Don't get the FAST it SUX!
Old Sep 15, 2005 | 10:43 PM
JarrettL's Avatar
Whoa, less harsh on the site sponsors.
Old Sep 15, 2005 | 10:56 PM
Phoenix 5.7's Avatar
he is just stating the truth for the most part. the quality on the FAST tb is substandard for the price, alot of ppl have had various issues with them. id look at the NW one.
Old Sep 15, 2005 | 11:26 PM
SUX2BU's Avatar
FAST can suck it. i got one of the FAST tb from a friend and had problems with it from day 1. I called FAST and asked what the "fix" was thgat they were doing. I called twice both times they said someone would get back to me. never happened. I didn't buy it from them so i didn't want them tro fix it for free, i just wanted to get it fixed.
I had to use FOUR throttle return springs so may car won't "cruise" at 60 mph when i take my foot off the gas. And i have to tap the throttle when i come to a stop sometimes cause theres too much play between the throttle botty cam thingy and the TPS sensor.
Old Sep 16, 2005 | 06:36 AM
LS2Monte's Avatar
I think I'm gonna get the Nick Williams TB...would I see a power increase with one of these over the stock LS2 TB? They are both 4 bolt 90 mm (correct??) but does the Nick William one flow better?
Thanks
Nick
Old Sep 17, 2005 | 08:07 AM
greentahoe's Avatar
Thanks
Nick
Im interested in this as well
Old Sep 19, 2005 | 08:04 AM
jellison's Avatar
Does the ECU have to have the flybywire part of the programme turned off by the pcm tuner?
Think I might get an LS6 with the camaro Tb as before and 85mm maf for next conversion after all - well this is what I am think right now!
Old Sep 19, 2005 | 08:57 AM
SS1875's Avatar
Thanks
Nick
I'm not sure of the flow difference, the NW is a 5 bolt but it will seal fine with 4, I used 5 as overkill. It is a very nice piece and I have had no issues with it at all....definately worth the $$$. i would recommend the NW to anybody !!!
Old Sep 19, 2005 | 11:39 AM
30th droptop's Avatar
I don't mean to hijack this thread, but I'm thinking about swapping a crate LS2 into my '99 F-body. Is the throttle body the only issue I need to worry about? Can I use my stock ECU (maybe reflashed for fuel curve, etc.)?
Old Sep 19, 2005 | 02:07 PM
Your stock pcm will work fine. You will just have to modify the wiring harness to extend the MAP sensor wires and knock sensor wires and re-tune from there. You would be better off using a LS6 intake with your stock TB than the LS2 intake. Or you could buy the 90mm FAST intake and a TB.
