LS7 clutch pics
EDIT: Mike, I now see from the pics you posted that the Z06 Clutch/PP wont work with a LS1/6 flywheel as you need the raised mounting points. I wonder why GM did this?
Now this is just speculation, but lets say the kit costs about $550... That would only be about 150 more than other clutch kits that dont come with a flywheel. This package would presumably hold similar HP to between a stage 2 and stage 3 clucth, while hopefully retaining stock like street manners.
To me that would be a hell of a bargain. Now all we need is confirmation that it works, reports that it performs well and retains streetability, and lastly a good price!
Original Thread
https://ls1tech.com/forums/generation-iv-internal-engine/356430-2006-c6-z06-ls7-clutch.html
I'm game for this setup in my 99 TA M6 if it is compatable.
Mike
Thanks again for the info!
I discussed the gap problem with the other builders and we all agree that the only way that could happen is if he installed the clutch plate backwards. The plate is marked "flywheel side". Have him check that. Other than that, it is supposed to fit."
Mike
mas280 for getting this all started and following through with his install!
