i want to buy a ls2 what all would i have to do to swap my ls1 wtih the ls2: injector
If you want to use the LS2 90mm intake you'll need - 90mm cable TB.
If you want to use the LS2 injectors you'll need - 8 wiring adaptor pigtails.
Another way is to use a LS6 intake, cable TB and LS1 style injectors...this works well.
You'll need -
--Oil pan, pickup tube, deflector tray, dipstick tube and dipstick to match your car.
--To check the balancer and water pump pulley alignment....if you got a Corvette spec LS2 the pulleys will be 3/4" too close to the block to run your current brackets and belt driven accessories. You might need to get an Fbody balancer and water pump.
--2x LS1 knock sensors. 1 x M10x1.5 thread tap.
--Small wiring mods or off the shelf pigtail adaptors ( extend cam sensor wires 22" and cross wires) + (extend both knock sensor wires).
--Gaskets and some new bolts.
--Tuning to allow for more cubes,different injectors and new knock sensor locations.
You'll need -
thanks how much would you suggest it all cost when said and done ??? 3800 for the block.....how much more would the .... tune and installation and parts cost?? another 2000?
