LS7 intake and heads
Intake-12569011 251.48 (decent)
heads- 12578450 515.35 no too bad..
I pretty sure the heads are bare though... but this would make a great package to your LS1,2 or 6 thats for sure.
just like AFR 185's VS. 225's..... bigger is not always better.
my $.02
brad
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
damit I forgot about the valve size...
GOD THERE GOES THAT PLAN......
wait what is the bore on a 6.0L iron block? will these fit the 6.0L iron block or Ls2? Best bet to use these heads is a resleeved ls1 or ls2 block. I believe darton just came out with a dry sleeve for the ls2 which will let you go 4.125-4.160" which would work very well with these heads.
Nate
The New head will use the stock LS1 valve train.Should be available sometime after the first of the new year.
We will continue too let you guys know everything we know when it happens.
Thanks again to everyone who supports us through this venture.
