LS7 design heads, variable valve timing, and forged crank for Trucks
Found this info on GMinsidernews
Link, towards the bottom
The L92 looks like a sweet engine, all aluminum, LS7 design heads, forged crank, VVT, and it also gets the new 6-speed auto hooked to it.
High-flow cylinder heads
The Vortec 6.0L and 6.2L engines offer a significant power level increase compared with previous premium engines, with much of the newfound power coming from high-flow aluminum cylinder heads. The heads are based on the racing-derived cylinder heads of the Corvette Z06’s LS7 7.0L engine, including a unique inlet port shape and offset rocker arm design. Airflow of the heads is supported by large 55-mm-diameter intake valves and 40.4-mm-diamter exhaust valves.
“The heads use the high-performance technology of the Corvette’s LS7 to build efficient power in truck engines,” said Meagher.
Variable valve timing
Variable valve timing (VVT) is a standard feature on 6.0L and 6.2L engines; it helps optimize camshaft timing to improve low-rpm torque and high-rpm horsepower. The introduction of variable valve timing through the unique dual-equal cam phaser is the industry’s first application of VVT on a mass-produced V-8 cam-in-block engine. The unique dual-equal phaser adjusts the camshaft timing at the same rate for both the intake and exhaust valves.
Cranks
All engines, except the 6.2L L92, use a proven iron crankshaft design and highly durable reciprocating components. The high-performance 6.2L L92 uses a forged steel crankshaft.
Cranks
2007 truck engines.....
6.0L aluminum block (L76) with Displacement On Demand technology and variable valve timing, rated at 355 horsepower (264 kw)*
6.2L aluminum block (L92) with variable valve timing, capable of 380 to 400 horsepower (283 to 298 kw)*
6.0L (L76) and 6.2L (L92) Gen IV Vortec engines use aluminum cylinder blocks, which offer reduced mass – an attribute that supports improved vehicle weight distribution and slightly improved fuel economy. The aluminum blocks are virtually identical to their iron counterparts, including a deep skirt design that incorporates cross-bolted main bearing caps and a structural oil pan. All engines, except the 6.2L L92, use a proven iron crankshaft design and highly durable reciprocating components. The high-performance 6.2L L92 uses a forged steel crankshaft.
The block for the 6.2L engine features a crankcase “windows” – vents that help improve bay-to-bay breathing. This reduces pumping losses and supports the high horsepower output of the high-performance engine. A new, 58X ignition system and a more powerful, E38 ECM are integrated on all engines
High-flow cylinder heads ...
Vortec 4.8L and 5.3L engines also have high-flow, Corvette-derived heads. They are based on the previous-generation Corvette Z06’s LS6 engine’s cylinder heads and have flow characteristics commensurate with the engines’ airflow-to-displacement needs. All the Gen IV Vortec engine variants use the same efficient ignition coil packs of the LS2 to light off the air/fuel mixtures that are drawn through the heads.
The main things everyone needs to know about the L92 engine...
6.2L
Aluminum block and heads
LS7 design heads with the offset rockers
Variable Valve Timing
Forged stock crank
Coupled to the new 6-speed automatic tranny
L92 combustion chamber
http://gm.wieck.com/forms/gm/previewpage?026549 valves
http://gm.wieck.com/forms/gm/previewpage?026546 valveless
LS7 combustion chamber
http://gm.wieck.com/forms/gm/previewpage?022797 valves
http://gm.wieck.com/forms/gm/previewpage?024297 valveless
L92 Intake ports
http://gm.wieck.com/forms/gm/previewpage?026548 intake ports
LS7 Intake ports
http://gm.wieck.com/forms/gm/previewpage?022803 intake ports
http://gm.wieck.com/forms/gm/previewpage?022800 intake ports
LS7 Exhaust ports
http://gm.wieck.com/forms/gm/previewpage?022799 exhaust ports
http://gm.wieck.com/forms/gm/previewpage?022798 exhaust ports
Exactly, they do look to be unported LS7 heads..............
Cam phaser...
http://gm.wieck.com/forms/gm/previewpage?026547
6.2 Block pics...
http://gm.wieck.com/forms/gm/previewpage?026545
http://gm.wieck.com/forms/gm/previewpage?026551
http://gm.wieck.com/forms/gm/previewpage?026552
http://gm.wieck.com/forms/gm/previewpage?026557
6.2L
Forged stock crank
L92 Intake ports
LS7 Intake ports
LS7 Exhaust ports
Cam phaser...
6.2 Block pics...
LS1Tech Premium Sponsor
These heads really do show alot of potential! The testing PRC has been doing on them seems to be very positive if we can get a intake that will allow us to run them on our cars
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I wonder how the variable cam timing works. At one point, I was told (in 03) that the C6 would have a dual cam in block design. This sounds like a single cam that varys intake and exhaust timing together.
But how?
P.S.
So the LS7 heads will, more or less, we the standard head going forward.
But how?
P.S.
why not just use the ls7 intake it is very affordable. Much less than a fast 90
Originally Posted by DavidNJ
If this stuff fits LS1/2/6, it will render all current heads and intakes obsolete for uses that allow it (some racing classes require heads that came with the engine).
Nate
Originally Posted by Nate_Taufer
It does and will fit the ls1/2/6 stuff. You'll just have to have a bigger bore to accomodate a 2.2" intake valve (see 4.060+)
Nate
Nate
Originally Posted by Spellbound
How did they get the extra .2 cubic inches, bore or stroke?
The intakes will not bolt up at all. They are definately different shapes. Even the rocker spacing is different from the LS1 & LS7 heads.
The only way I see the 6.2l head fitting on a ls1 car is if we luck out & GM's truck intake fits under the fbody cowl.
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
i think your right about the 4.125 bore on the 6.2
it make sence since they dont use a bigger stroke on the 6.0 motors just a biger bore
i think that these blocks are going to be awsome and relitivly cheap
LSxGuy widda 9sec Mustang
The LS7 intake runner is .400" higher from the deck than the 6.2L, checked that 3-4 months ago. The rocker spacing holes are about the same, although the pedestal is built into the LS7 head while the 6.2L is flat milled like the LS1's have been.
69cc
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
www.texas-speed.com
(806) 866-0734
www.texas-speed.com
(806) 866-0734
