lucas 42 lb injectors/01 rail on ls7 manifold
Does anyone know of any fitment issues with this setup? I understand the ls2 manifold is a bit different, than the older ls1/ls6. Just wondering what I will have to do, if anything.
I am guessing that the LS7 will need LS7 rails. When you get your LS7 manifold, you will need to measure the distance between the injector holes. Do you still have the LS1 rails lying around? Most injectors are univeral, so I hope off the shelf ones will work in the LS7 manifold.
