LS7 - why not forged pistons?
If there's a good reason...OK...if not the "moron" stands.
I have heard that GM has made a forged piston that you can buy over the counter that can be installed without re-balancing into the LS7 engine.
Don't you drive there to get tested?
Can GM not build an engine as good as ARE so it doesn't have piston slap
Automotive materials specialty engineers please enlighten us lay people that just want to go fast
If they havent expanded to their full size they will hold less compression and cause more CO emissions when cold.
RIGHT?
regular aluminum is fairly easy to forge. The more silicon that is added to the aluminum, the tougher it gets. Eventually it gets to a point where the Dies wont last long enough to make it worth the extra silicon. Normal hypereutectic pistons arent weaker than forged because they have a high silicon content, they are weaker because they are CAST. of course, super high silicone content makes the piston brittle, but I havent seen any pistons that bad.
one company makes forged AND hypereutectic pistons. MAHLE forges pistons with a Silicon content more than 12% which is high enough to be considered hypereutectic. these have all the Benefits of a forged piston, with the expansion properties similar to a Cast piston. that coupled with coatings that are application specific makes for a superior piston, IMO. German and British tuners have been using Mahle pistons for years under High boost, continuous high Rpm duty (autobahn) and in my boats, I've spun Mahles 7500-8500 for 20-30 minutes at a time with EGTs up around 1200 degrees, they hold up awesome. I cant figure out why they havent caught on over here.
other than possibly the price.
other than possibly the price.A freekin mercedes has forged pistons.
